OBA System ARB vs VIAIR??
I cannot offer a comparison or recommendation between the two systems, as I have never run the ARB setup. I will say, my Viair setup works flawlessly and runs air tools and airs up anything very quickly.
Ed
This post is for a 7.3 Tremor with dual batteries. Very clean ARB install under the hood.
img_1038-jpg.21865
what ever happened to that guy that was making up a bracket for the Air Tank and Viair Compressors. The one that went around the Spare Tire .. Did that come and go .. maybe I missed it. I still haven't installed my Air Tank and Compressor.
He wouldn't even respond to a direct message. There are online fabricators that could have cut and coated his pattern while he could have taken his royalty off the top of each sale - but apparently sharing out that CAD file, while retaining full rights to the design, was not something he was interested in.
Here's my setup. ARB twin compressor feeds the 2.5 gallon tank, with a quick connect mounted to the bottom of the hitch receiver. It's a good spot to reach all my tires on the truck and a trailer, or to adjust my air bags.
My viair compressor and tank are in the truck box. Drilled one hole in the bottom of the box to run wires and route the air lines. Air horn is mounted under the frame on the passenger side of the truck and the air chuck runs up over the spare and comes out next to the rear license plate.
Once I find a couple hundred bucks sifting around I want to add air to my truck. 🤑 That and an air horn. 😬
I will update photos of my twin ARB unit. I have the 1 gallon ARB tank may or may not use. I need to think about it for a few days before the install happens. BUT it will be a top notch job not going to half ass it just to get some air.
There is no room under the hood of 6.7 for the twin.
Here is my twin install. Don't mind the stack of washers as spacers as that is getting replaced soon with a shorter bolt when I install the Viair tank. I bought bolts initially but they were the wrong thread so I need to go back to the hardware store.
You can see that spot is nice for the short ground to the frame where the existing harness was grounded. I just ran the two power wires and the switch wire in the wire loom along the existing harness up to the engine bay. It got a little tight near the fuel and Def tanks but it made it through after fishing a line first.
For now I also have the air chuck in the pre-drilled slot on the hitch. I was planning on moving into the bed but haven't decided where yet.
Gonna be watching for your ARB Twin Installs.
Anyone considered or used the Outback ExtremeAire Magnum 12V?
They seem comparable. I've seen a few complaints about ARB reliability, just curious if anyone has used this brand.
I use a 15lb Powertank CO2 @ 300 PSI hose pressure as my main squeeze which gives me 3 all around fills from 20 PSI. I have a portable dual ARB as a backup. An 8foot safety inflator with a 150 PSI electric gauge keeps me from bending over.
I went with ARB twin. I mounted the compressor on Builtright rack, tank vertically (necessary for condensation draining) under truck, and hose coupler on drivers side. I used existing holes to run my lines, but drilling new holes could provide a cleaner install. I wasn’t 100% certain on the locations, but I am now, so I may clean up the lines.
View attachment 42736View attachment 42729View attachment 42730View attachment 42731
Where did you mount your tank?
Due of the lack of a condensation drain valve, I was committed to hanging the tank vertically for ease of maintenance. I played with this decision in a dozen locations. I have power running boards and I couldn’t find a location that was visibly hidden and protected on the side rails. I ended up mounting it vertically in the space just in front of the fuel filter on the cross member. The fuel filter housing hangs lower than the air tank. If you have a larger fuel tank that space may not be available.
If you had a peanut tank that could be mounted horizontally with a condensation drain valve, you definitely would have more options. As you know the advantage of ARB is the size and 100% aluminum. Good luck!
I've had the best that both brands offer. ARB is a better product hands down. They have great customer service too. I have the dual on my truck and my Jeeps. They're expensive but I have no regrets. Fills my from trail pressure to road pressure in about 2.5 minutes per tire.
View attachment 42351View attachment 42352View attachment 42353
How do you have the compressor and tank mounted? I don't see any hardware that they are mounted to in your pictures. I just bought this exact setup and want to mount it in a similar orientation.
I'll get you some pictures of the mounting, as best I can. I had the system installed at Direct Offroad in Bakersfield, CA, and they did a great job.
I've got the Klein air horns onboard air system. I skipped the airhorns (because I'm not a child) and went with just the compressor and the tank. The tank goes above the spare tire. the compressor goes on the passenger side rear frame rail. brackets are nice. install was good.
