I never made any claim other than it was a performance improvement- which is true by your own standard.
It's an HD truck. It's not an offroad beast. It's not a Baja champ (neither is the Raptor, if we're being fair). It's not even a good trail rider. It's a tow pig with a cheap lift and lockers. If that's not what you were looking for you bought the wrong truck.
Removing safety nannies is not the same as
improving the performance. Performance is improved by remapping parameters in the engine, exhaust, transmission, suspension and steering. You can interpret what I wrote anyway you want, but AT Sport Mode on a SD is not the same as Sport Mode on other vehicles Ford sells and I never implied anything different. Even Ford does not believe pushing the TC button twice is a performance feature or they would have put the option on the drive mode button, like they do with every other performance vehicle they produce.
On your other point, I always do my research before spending money on a new vehicle, so I knew exactly what I was getting when I bought the Tremor. It is an 8000 lb SD truck with 1050 lb/ft of torque, 1-ton leafs and Dana M275 rear axle to pull my 36' long, 10,000 lb TT with relative ease. My Raptors could not handle the tongue or towing weight of even a small camper.
I swapped out the cheap lift and Tremor shocks for a true suspension from Carli, shocks from Fox, along with airbags from Air Lift, but even now I do not pretend that it is an off road beast or a good trail rider. I use it to tow heavy and occasionally drive off road when camping. If it is not towing my camper, it is sitting in my garage. I have a GT350 if I want to drive a vehicle with a Sport Mode feature that actually improves performance and boy, does the 5.2L FPC sound awesome above 4000 RPMs when I take it out of Normal Mode.
