Not really a fan of this 10 speed
MCTremor
Tremor Buff
South Carolina
Marine Corps Veteran
2020 7.3L Tremor
1968 Cougar XR-7
I am going to start by saying I fully understand this is not a sports car.
That being said I really wish these things didn't shift into 5th at 15mph with little to no throttle input. I have been having to drive around in the city more frequently and there are 2 types of drivers there, ones that want to do everything at 5 mph and those that treat it as a race track.
Going into 5th at 15mph robs the truck of ALL go and when you floor it to get some back it feels like it takes 2 whole seconds for it to give any feedback!
On the flip side you can be coasting around a corner or turning with just a little bit of braking and get a semi aggressive down shift into 4th that's enough to lurch you forward just enough to notice.
Do tunes help this at all? I am getting a little tired of the slow reaction to throttle and the obnoxious shifting to high gears so quickly.
Other than that I do really like this truck and when towing it gets the job done well.
I believe you can lock out the higher gears, if you want to, when you're driving in town. I know you can on the raptor. Don't remember off hand how many you can lock out.
You can lock out all but first gear. Unfortunately that doesn't change the programming and it will still fast-forward to the highest gear available.
My best recommendation is to use Tow/Haul mode. It's the closest thing to “sport mode” programming this truck has, it seems.
Look at the Bank’s Pedal Monster. There are several threads in this forum detailing how it can help with pedal lag. They had a group buy on them a couple of months ago…
Another option here is to add a Raptor steering wheel with paddle shifters. That, I believe, enables you to manual shift from paddles on the wheel versus the awkward lockout from the stalk thing.
I haven’t done this so someone else can speak to the value.
I do know that when driving in the city in any other vehicle, I prefer paddle shifting to leaving it in auto.
It'll still shift however it wants - paddles act the same way as the +/- on the column shift - only advantage is easier access at 10&2. The paddles are useless for normal driving if not towing.
Livernois Motorsports has a tune for the 7.3L, if that's what you are rocking. They are well known for their tunes on the ecoboost motors. I am definitely going to end up going this route. They are somewhat local to me (Dearborn, MI). They bring back some of the dead pedal you are experiencing. They tweak the trans shift pressures and shift points with their various tunes.
It's a lot of gears. Mine seems to always be higher than needed and even with the Bank Pedal monster there is a lag with the downshift.
But then when it does..........look out.
I like the idea of 10 speeds and its very smooth but I would guess there are more moving parts to deal with come rebuild time.
These trucks have a sport mode, most don't know how to activate it. Click the traction control button twice and it should show sport mode.
After doing a little reading on this forum, pressing the TC button twice does nothing performance related to the truck.
Sport Mode
Love the 10er with the PS but then it's always in its power band. 😁
I've read that the 7.3 is at
Sport Mode
It partially disables traction control, which will stop automatic breaking if the wheels break loose from a start. It absolutely has an impact on performance, but only in those specific scenarios.
This is the same mechanism as several other truck manufacturers use - not specific to Ford.
Putting my Gen 2 Raptor or GT350 into Sport Mode changes engine parameters, suspension parameters, steering wheel parameters and in the case of the Raptor, transmission parameters. The Tremor has none of those performance benefits and I would not consider removing traction control a performance boost, but rather the absence of a performance inhibitor.
You're comparing bananas to whiskey. I don't disagree with what you're saying, in principle, but you're caught up in semantics.
Your argument can be used against you - if putting the Raptor into "sport" mode changes throttle mapping and shift points to give a sportier experience, wouldn't that also be disabling performance inhibitors? Shouldn't the vehicle always be in sport mode?
So no, "sport trac" doesn't change throttle mapping, shift points, or suspension, but it does turn off a nanny that inhibits performance, in the same way that putting another vehicle into "sport" mode turns off the computer restrictions that make the vehicle run less optimally.
Haha! Your final paragraph states the true facts, that the Tremor Sport mode is not a Sport mode at all. Thanks for the laugh!
I like bananas. I like whiskey. You got me thinking.
