Needing some 5th wheel towing advice!
Reviving an old thread but I finally pulled the trigger on a BW companion slider hitch after too many hours on other forums regarding slider vs non, brands etc. This may be way more hitch than I actually need but I can sure be confident that camper is plenty secure.
B&W hitches are beasts. I have the same but non-slider version for mine. I run a Reese Sidewinder to give more turning radius so I don't need the slider. Can get about 130 degrees. Will tear up the spring shackles from side force before hitting. (Adding additional supports to spring shackles because of this.)
