Need advice for a Hi-Lift or not.
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
My thoughts... I Hi-Lift isn't just a lift... it's a recovery tool as it has many uses and proper training should be had by those that want to get their money's worth and some. I'm a believer that gear we carry in our trucks should have multiple uses so as to minimize carrying extra gear that is single use case only. A Hi-Lift meets this criteria for me as a very versatile tool since it can be used for winching, recovery and lifting a vehicle (mine or others') on the road and on the trails. It can even help with de-beading a tire for tire repair situations. I personally have a Hi-Lift extreme model and was trained on how to properly use it in various scenarios on my truck in adverse conditions by Morrison's Outdoor Adventures (the lead trainer Mike Morrison is the real deal and he himself uses a Hi-Lift for recovery situations with his full size diesel truck). When used properly a Hi-Lift can easily help with tire changes on-road and with some know how, do the same off-road.
One thing to consider, in adverse conditions, getting under a vehicle to lift the truck (i.e. under an axle) may be difficult or impossible to do depending on the situation. With a full size truck like ours, a Hi-Lift allows you to use the lift on the outsides of the vehicle... specifically away from danger. In ideal conditions it's arguably easier and faster to use bottle jacks or some form of "offroad rolling jack" that I see advertised all over these days. But if you prepare for ideal condition recoveries then you open yourself to being unprepared for that one time conditions aren't ideal.
For our trucks if you need to change a tire, simply attach the Hi-Lift to the front Tow-Hook or the rear receiver. In the front I use a soft shackle to create a loop through the tow hook. In the rear I use a Factor55 receiver tow point and then a D-ring through that.... from there attach the soft-shackle to the D-ring and lift away. A Hi-Lift Extreme easily handles the load of my 6.7PS Tremor.
But beware, there's a lot of fakes out there offering cheaper solutions... but there's only one "Hi-Lift"... specifically the shearing pin is their magic. Under too much load, the pin shears and the jack stays lifted... all others fail and the jack drops and if you're under the truck, that's a bad day.
All valid and true points. A Hi-lift is very much like a framing square in that it has a hundred other uses besides making square connections and lines. Training is the key. Most that own a framing square only know how to do about four things with it.
I think you would agree that short of attending an advanced class, most only know what they've read on the internet, and that trial and error is a very dangerous way to learn how to use a Hi-lift in extreme conditions. There's a lot of mall crawlers out there with light bars, winches and Hi-lift jacks mounted across the hood that will never, and probably should never see actual use by the owner for this very reason.
If serious off-roading and rescue is the intent of owning a Tremor, I say by all means get a Hi-Lift and the appropriate accessory rigging to go with it, and schedule some real training before you need it. For the other 95%, get a good bottle jack and toss out the factory jack. ?
Thank you for that well though out and informed opinion.
I've got a hi-lift jack mounted to my built right industries bed system, I also have the attachments to pick up the truck from the wheels or sling to the frame. I've never had to use it on my truck but it's there for if and when I need it.
