Mystery water leak / intrusion
If it is the rear window leaking - is there a specific sealant I can try to use around the window to seal it up myself?
What about a sealant to use around the slider? I never use it anyway.
I know insurance will replace a rear window if the little defroster tab is broken. Maybe they will replace a leaking window.
You can seal the rear window. Apply the sealer like you would apply chalk to a house window. You’ll need to inject a suspect area, wait to cure, then retest. It can be time consuming. Google windshield sealer.
Is there a certain type of sealer you would use? Butyl, silicone, acrylic, polyurethane?
At the plant we used a clear silicone sealer for small leaks.
So my leak is coming from the rear sliding window lower corners.
Can I unplug the window motor and seal the rubber from the outside with silicone?
Im not sure if silicone is UV resistant or if I should try this black E6000 adhesive I have.
Any advice or experience with trying to reseal that window?
No warranty? I assume you could do those things, but I personally wouldn't. Unless if course you are out of warranty. Even then I would probably just try to get a new seal if it is repairable. Again, personally.
Did you notice any debris or damage to the rubber? Pictures of so?
You could unplug and seal the window. I would see if a body shop or ford dealer will help you fix it. You’ve already torn it down so the labor cost will be minimal.
Like others have posted, check the seal on the 3rd brake light.
This was my leak. I found a youtube video that showed me how to remove it, place a bead of silicone, and replace it. I had water on my rear sliding window also. This 3rd brake light is such an easy fix and takes only minutes, I would try it first.
My 2022 F250, 18K miles, $90K Truck, 10 months old, water leaking right in from this vent.. Unbelievable Ford can't / wont correct /address this poor design. I am taking my truck in under warranty, however now have a truck with wet musty carpet that has to be torn apart to hopefully solve the problem. Known issue that will cost a ton of money for trucks out of warranty, for a $5 dollar cost part at best. Bought a Ford over a Chevy as my last vehicle hoping for better quality. Appears all car companies are the same, quality is behind profit.
I would get out as much water as possible then dry your truck out before it molds. Turn the heat to as hot as possible, floor and defrost setting. Crank your truck with the windows up and let it idle for 30-45 min. Check and see if all the dampness is out. If not repeat.
Thnaks for the reply.. Taking it in today. Not sure what they will say but as it is under warranty, we'll see what Ford does, new carpet should not be out of the question. Just disappointing quality for the price..
Agreed.
My truck was just out of warranty when the rear slider window started leaking. The carpet was soaking wet and musty. I bought a mold and mildew spray from ace hardware that took it all away. I had to remove the seats and dry out the carpet and then sprayed everything with the mildew spray. I sealed up the rear slider and have had zero issues since.
Oh.... and I also applied some sealant around the cab vents. I live on the oregon coast where its always raining. Its been dry in the cab ever since!
Need advice!!!
Finally getting my leak fixed under warranty. It’s the pressure relief vent behind the rear right seat. My dealership is saying it’s a bed removal operation! Based on A-rods video it looks like a simple fix. Anyone try this on their own?! I’d rather do it myself then have them remove the bed, mess stuff up and have my truck gone for a month.
A ford dealer can remove and reinstall the bed quickly. I would not worry about the time to repair, the wait will be how many vehicles are in front of yours.
Need advice!!!
Bed removal not required. You can DIY as well:
Awesome, thank you. Biggest concern is truck sitting in sun at dealership,
windows up, mildewing, awaiting fix. Think I’d rather do this one myself.
It's a tight fit, just take your time. Do it in the cooler part of the day if you can, will be less stressful.
Edit: you may even be able to reuse your existing vent, it just may not be clipped in all the way.
