Mystery water leak / intrusion
Turn the Climate fan on high and run a soapy sponge over everything and watch for bubbles.
Just tried this to no avail. I couldnt see anything. I even taped the cab vents shut to create more pressure.
Oh, and to the preventative maintenance I was talking about. I just meant if you find your problem I can inspect mine in that area and see if I need to do something before it happens to me. All it takes is a small fold or paint drip or debris to make a gasket leak, especially in rainy wet regions. 👍 I probably don't get as much rain as y'all do, but I get enough
I live on the oregon coast. 🫣
I’ve become a leak expert unfortunately. 😌
I no longer get cab lights, or a sunroof. Less holes in the metal the better Imo
Try parking at different inclines and check for leaks also. Does it leak when the nose is up or when it’s down?
Water takes the path of least resistance as we know. These can take a long time to fix. That’s why dealers are usually useless when chasing leaks. They don’t get paid enough hours to find the leak. (Under warranty)
I’m sorry. Super frustrating stuff
We get plenty of rain here and the driveway has a slight angle to it so I will try parking in both directions.
Tried flooding everything and I couldnt get any water to leak in. Kind of a good thing but also perplexing
According to his first post, he already tested the rear cab vents. Unless he just looked at them and thought they were good.
Vents dont leak and I have found water drops higher up above the vents. Its gotta be the rear window seal or the cab trim seal. Maybe one of the two antennas but they seem ok. 3rd brake light was good n dry.
I just tried to flood everything and zero water in the cab 🤷‍♂️
So, with my wife owning an HVAC construction company, I've become pretty acquainted with smoke tests. It might be worth calling up the dealership to see what their protocol is for smoke tests; I know that some dealers have experience doing this. Ford might also assign you an engineer that can assist with this.
You won't know if you don't try it. Having personally run a few smoke tests in airline terminals, I can say that the smoke bombs used for this stuff don't leave a lasting smell...so don't worry about that. Sorry to hear about the issue though! It also seems likely its got to do with the rear window seals as others mentioned. Any heavy hits from off-roading certainly could unseat a seal that would allow for this.
The cab trim is only decorative, it covers but doesn't seal the ugly cab seam. Not saying it can't be the cab seam, just saying it should not leak from that seam even if the trim was completely gone.
Looking at the pictures again the 2 globs of urethane above the grounds on each side don’t look right. Usually the urethane bead on glass is uniform so it spreads (seals) evenly. Those look like the robot had an issue. Try putting a hose under the backglass in the area of the blobs while you watch from
Inside the cab.
Inside the cab.
Ok. That does seem like an overkill amount of sealant right there that just exists for no real reason. I will flood those spots really well tomorrow and see what happens.
Long shot but any chance a child or a certain woman spilled a jug of water and conveniently forgot to tell you?
I’ve seen that too. A leaky gallon water jug leaking into the carpet of my friends Truck
They would have had to splash it up on the back wall of the cab behind the rear seats somehow.
Here is another idea. It's outside the box but, it almost seems like water blowing in from the rear doors. Are there any water drops towards the middle? Check your back windows to make sure they are all the way up. I've accidentally left mine down a fraction of the way where they looked like they were up, but they weren't. Also check the weather stripping around the rear doors.
This is on a 150 but the rear glass should be the same as a Super Duty.
I was hoping this wouldn't be it. Didn't really like the idea of the sliding back glass. Hopefully this isn't his problem. I plan on putting a topper on and inflating a bicycle inner tube between the two glasses so I can have a "climate controlled" camper shell so I probably won't have this issue😜
Wildabeast, you can also apply shaving cream around the gasket of the rear outside window and 3rd brake light and with a hair dryer blow air from the inside all around the window and light. If the shaving cream moves while blowing air there is the leak area. Simple idea sir. Good luck.
This could very much be the leak. It started again last night when parked nose down. The water was built up between the rear glass and the metal of the cab.
Either the window seal or the window slider seal I think is leaking.
I think this may be the issue. I am getting water build up in the gap between the bottom of the rear glass and the metal of the cab.
Its either getting in the window seal or though the slider window seal.
