yea...thats about the same time one runs out of common sense too..It doesn’t feel that fast the only way I notice is it stops accelerating.
Mine stopped going any faster right at 96 mph “out west”. So I know it has a limiter and that is the speed on the digital speedometer that it indicated, however my truck‘s speedometer is 1 mph slower than it should be. I did have a ”chase vehicle” pace me and his read 95 mph.Have hit 90 a few times passing tards. Was still pulling hard.
It should have a kinetic energy gauge.
That's what I understand too. My Porsche is the same. Limiter was set based on tire speed rating. Pretty common I think.To clear it up: these trucks do indeed have a speed limiter, and they're speed limited because of the tires. The tires are only rated for 96mph or so.
Truth based on my experience over 14K miles.You’re probably not going to like the sounds of this, but 50-60mph is the sweet spot for this heavy pig. It shifts into 10th right around 50, so couple the top gear with low RPM and minimal wind resistance (obviously it goes up as speed increases), and you’ve got the formula for getting the best results.
Yeah it doesn’t get any faster unless your going down a 6% grade with a tail wind. Been limited a couple times passing slow moving tourist on I70 between Denver and Green River Utah. No death wobble and handles pretty damn good for a heavy pigI cannot validate this to be true, but had several guys tell me ~95mph is where the limiter is set. I’ll never find this out myself……4 tons moving that fast is insane on public roadways!!
Same exact result and driving style for me as well modified! But I’ve never had a tank range more than ~650’ish.We decided to do a last minute trip to the Smokey Mountains to escape the hot weather here in Texas. So far, I’ve been averaging over 21mpg. This is going between 75-80mph. I’m still running stock tires at 60psi in the front / 65psi in the rears. The photo is after I filled up at Buc-ee’s in Crossville, TN.
I’m not a heavy foot driver, but don’t baby her either. Run in “Normal” mode not Eco, 62psi all the way around. so not sure unless you’re in higher elevation. I’m in GA at 800-900ft.I have no idea what you guys are doing to get over 20mpg.
I've tried 60 to 85mph each week and never get better than 18.5 hand calculated.
Average is about 17.1.
Must be a '22 thing or something, I have 355 gears and 31" tires @60psi and all freeway driving mostly flat.
How many miles do you have on it? Fuel efficiency tends to increase as the engine, transmission, and rear diff break in. I have almost 15,000 on mine now and will average 21 when going on long trips at around 60mph.I have no idea what you guys are doing to get over 20mpg.
I'm light on the pedal, maybe have hit full throttle 3 times just to see how it runs, I'm at 3626 miles, maybe it's gonna get better after the first oil change.How many miles do you have on it? Fuel efficiency tends to increase as the engine, transmission, and rear diff break in. I have almost 15,000 on mine now and will average 21 when going on long trips at around 60mph.
Very true, I commute downtown ATL 3 days a week and mileage is vastly different in those city slicker conditions. I was showing optimum interstate travel conditions as the OP asked how anyone was getting over 20mph.It is not only about driving styles, it is also about the type of driving. At 8000 lbs, its a load to get moving, to change speeds & to climb grades. When I am in town, in stop & go traffic, or driving thru the hills my mileage decreases significantly. When I take longer trips & can maintain speed, the 10 speed goes to work & mileage is pretty darn good.
In S. Cal you would get run off the road at 65-68 - people are moving here - 75 + is not unusual flow of traffic - well until if just stopsOn the interstate I tend to move at 65-68. I have absolutely no reason to drive faster than that in this tank.
If I was to drive like an idiot - I take the BMW.... (the old forum members will understand that last comment -![]()
It would be a good idea to get on it hard a few times while going uphill (such as an on-ramp) to build some good cylinder pressure and ensure the rings seat well. Also good to allow the engine to slow you down going down some steep hills now and then during break in to help seat rings.I'm light on the pedal, maybe have hit full throttle 3 times just to see how it runs, I'm at 3626 miles, maybe it's gonna get better after the first oil change.
I'm in socal area by Temecula.
The truck trip computer is either same as or reads half a mile more than hand calculated mileage.
Yeah, there are a few angry drivers from NY, CT, and MA who fly by me. My wife tells me I drive like an old man in it...and I do...and I kinda am. lol She does not complain when I am pulling the trailer with her horse in it, though. lolIn S. Cal you would get run off the road at 65-68 - people are moving here - 75 + is not unusual flow of traffic - well until if just stops
I drive 65 miles each way a few days a week to my SD office - I go down at 5:30 a.m. for traffic reasons - drive flow of traffic going, which at that time of day is 80+ - get 15 mpg +/- - coming home around 3:30 in the afternoon the traffic flow is 65-70 - get 18 mpg +/- coming home - truck computer measured.
60 gallon S&B tank has been a blessing (and a curse filling up at $6.59 a gallon here in S.Cal). I have 1.5" lift over OEM and 37" Toyo AT III tires - lost 1-2 mpg when I did the suspension upgrades.
I have never been one to drive for mileage - but can clearly see it go up at 65 or less as noted by others!
