Morimoto XB center marker light/limitless auto works issue
6.7spoolin
GB Coordinator 📢
Pittsburgh
I just wanted to share my experience with the Morimoto center marker and limitless harness. For anyone that was considering that combo.
A few months ago I added the Morimoto center marker with the Limitless Auto works harness. There was a connection issue so I contacted morimoto (thinking it was a bad light) and they sent me a replacement. Well the issue was still there. So I reached out to Limitless and they blamed the pins on the non OEM light and recommended slightly bending them. That didn’t work either. I was able to add solder the pins and that gave it a better connection. I don’t think it’ll be a permanent solution but I was crunched for time.
Overall the light itself though is pretty bright and the brake feature is a bonus. I tied into the high mount wire and it works perfectly.
For the price I’d say the light is worth it. I probably would have sourced the plug and made my own harness if I knew it wouldn’t have worked correctly.
