Featured
- OP 🔹
- #21
I have not connected a fuel gauge. However, I did run forscan while driving and there is not any change during sound that I can find both heavy highway driving and stop and go. Also the SB replacement tank is molded plastic..I think.Have you connected a pressure gauge to the fuel rail during your traffic light to traffic light driving? see if the pressure changes much. I'm in agreement this sounds like a failing fuel pump but I'd be curious if it's failed (dropping pressure) as well.
The other thought that occurs as i type the above, with the fuel tank now being steel I wonder if you're just hearing the pump more as it can reverberate off the steel structure versus the more absorptive plastic from factory. Meaning there may not be a way of alleviating the noise entirely.
Here is a list of all things tried / symptoms from all other user and myself with no solution yet to help others
New LPFP (CDUB19)
New pump controller (CDUB19)
Sound coming from both stock tank (modified) and aftermarket SB tank (Mine)
Sound coming from both HSM fuel components as well as stock components. (Mine, CDUB19)
Known TSB to "fix the sound" TSB 21-2057 - (Performs the top two items as well as reset in forscan, no solution problem continues, Helpful video for folks if they want to do it themselves:
Thanks all for the help and maybe one day we will figure this out. My ford dealership says it is just normal operational sound.
