- Sep 12, 2022
- 210
- 330
- 2022 F450 Platinum Shortbed by DBL Design
- 2017 Porsche 911 Turbo S & 2021 Polaris Pro XP 4
EOG doesn’t want to modify the drivetrain, ECU programming or even aftermarket brake pads/rotors. They want it to be stock as possible, which is good and bad. I believe the one piece aluminum wheels they use are made by Hutchinson.
I have driven an F550 by EOG with 4.88’s and 40’s and it was slow. I realize some of that is because the cabin chassis and they don’t have as much power but it needs more gearing to get off the line. I definitely would not recommend 4.30 gears and 44’s. If your ever in the salt lake area I will spin you around the block in my truck with 42’s and 6.17 gears. It’s a solid combo. I personally think 44’s are a little too heavy and you lose a lot of stopping power and emergency maneuverability with the added weight of 30lbs more per corner, but they do get a lot more attention
