Lessons learned with fuel filter change on 6.7
Crestwood, KY
Not sure if anyone has had the same experience but thought I’d offer up my experience today. This isn’t my first rodeo changing the FF on my ‘24. I remember the first time I changed the FF @ 10k I had read posts saying to do it with minimal fuel in the tank. So I did. Changes at 10k and 20k had no issues. Decided to change them today after clicking over 30k. Sitting at about 3/4 of a tank and figured it couldn’t be that different. WRONG. I drained 2 gal out over 20 min or more and decided “that’s got to be good enough” even with fuel still draining out and when I went to loosen the 8mm housing bolts fuel dripped out around the bolts. So, I drained more for another 10 minutes, went to take the filter housing off and was greeted with a deluge of diesel fuel. It was all I could do to get those bolts tightened up as quick as I could to lessen the bath o’ kerosene I was taking.
Lesson learned. NEVER again will I attempt a filter swap with more than a 1/4 tank.
Wife didn’t even think I smelled sexy 😒
What about putting a latex glove or cellophane over the fuel fill next time so it can't siphon?
Did you disconnect the upper filter connections first?? :unsure: :unsure: :unsure: :unsure: :unsure: :unsure:
:cool::cool:☕☕🇺🇲🇺🇲🇺🇲🇺🇲
