2023 Dodge Challenger Hellcat tune turns into a $36,000 repair bill
A 2023 Dodge Challenger Hellcat owner made a warranty claim over a broken engine, but a PCM code that can't be erased alerted Dodge to void the warranty.
Very true, if you tune your vehicle don’t expect the manufacturer to cover it under warranty.Ford can and does check the ECU. My 14' GT500 threw a valve at six years 55k and it sat for a day for them to check the computer so the Extended Warranty folks would approve repairs. In this day an age I think they all know if you jailbreak your electronics.
as a VW connoisseur and recipient of TD1 award can confirm this. Thats one reason they went around and required modules to be coded to keys and only allows one key set to be coded to modules at one time (so you can't hot-swap ecus) and when you would go into VW for service (or their other brands) they would plug into and connect to the mothership in Wolfsburg and basically compare code lines and checksums. In the beginning, they were plugging in every vehicle regardless of the "service" you were in for. Guys were getting TD1'd just for oil changes and tire rotations.I believe this has been around for quite sometime. Not sure who started it but over a decade ago, Audi was branding tuned cars with the “TD1” flag. Usually only based on plugging a tuned ECU in and getting an altered calibration or out of spec flash count on the ECU. Flash count being different from what Audi global believes that vehicle should have based on its service history.
That act applies to aftermarket replacement parts. The ecm was tuned to deliver more hp, one piston lost all compression which could have been caused by the tune running lean. That act doesn’t apply to someone changing their software to have the vehicle make more power. The owner should have bought a mopar tune, left it stock or had the funds ready to cover an issue like this which was related To tuning/altering the vehicle.One would think that the Magnuson Moss warranty act would still cover an owner from complete warranty voiding. ...the dealer or manufacturer would still have to prove that any modification caused the issue under consideration.
Fair enough. I was considering the software the aftermarket replacement part, but I see your point. Obviously, if you tuned and subsequently lost compression, and the dealer/manufacturer said it was your tune, you'd have a hell of a time proving it wasn't.That act applies to aftermarket replacement parts. The ecm was tuned to deliver more hp, one piston lost all compression which could have been caused by the tune running lean. That act doesn’t apply to someone changing their software to have the vehicle make more power. The owner should have bought a mopar tune, left it stock or had the funds ready to cover an issue like this which was related To tuning/altering the vehicle.
MMA is always spouted but the problem is:One would think that the Magnuson Moss warranty act would still cover an owner from complete warranty voiding. ...the dealer or manufacturer would still have to prove that any modification caused the issue under consideration.
Agreed. I mentioned that in my reply to Explorerinil above.MMA is always spouted but the problem is:
You blow the motor (regardless of fault) but have a suspected part or ecu tune
Ford: you modified it we believe this to be the issue, warranty claim rejected
You: that didn't cause the problem
Ford: yes it did, warranty claim still rejected (car can sit or you come get it)
You now have to get a lawyer to go against fords lawyer panel.
Your car sits in what is now litigation, mediation, arbitration and through negotiations. Ford ties this up in legal proceedings that take 1-4 years
You carless and making car payments, who then potentially loses and now pays court fees and potential defamation suits bc you got mad and made a bunch of angry fb posts.
Even worse yet now, FORD even notifies you under the hood of your vehicle now that non-OEM parts could risk warranty coverage should their be a component failure. AND some manufacturers now in the fine print when you sign for the car under warranty stipulate aftermarket tunes void warranties and by signing this you concur to these agreements.
yea i think you posted that while I was typing mine lolAgreed. I mentioned that in my reply to Explorerinil above.
there's something to be said for those that have experienced the screaming Chewbacca that is a straight piped 6LitreAfter reading thru all of this , I believe my '06 F350 6.0 just became more valuable![]()
