I'm assuming the posts would be on concrete - he's pouring footings and a pad - attached (and gapped off the concrete to eliminate moisture wicking) with appropriately engineered ties. If it were my patio, I'd want fewer posts. Yes, the posts should be sized for the loads. Ostensibly, and if it's attached appropriately, the rim joist attached to the house will carry some of the load to the house footing. I'm just pointing out that by adding material to the header, he can span farther between posts. It would also be much cheaper if he sticks with the steel jacks, as he'll require fewer of them, and they're more expensive than wood. As is, it's a forest of posts. I'd want fewer posts to make the patio more useable.
