- OP 🔹
- #21
I like knowing what gear I’m in…..but each to his own.
Its easy to turn off if it bothers you.
Care to share how? The +/- buttons take away the actual gears, not just the numbers, and it will not remove the 1st gear.
Well, I’m wrong, just checked.Care to share how? The +/- buttons take away the actual gears, not just the numbers, and it will not remove the 1st gear.
I might not understand what you are trying to do. I thought you wanted to just remove the gear number indicator on the instrument cluster. At one time putting the truck in drive and pressing the + button once would make all the numbers disappear. It would not eliminate the actual number of gears that the transmission will use. Is that not what you are trying to do, or is it just not functioning in that way in your '22?
Sorry, just noticed it was tried and found not to work in the post above. That is the only way that I have ever heard of to hide those numbers.
I'm surprised there isn't any way to have the truck start from 2nd gear? I tow very little and most often it seems starting from 1st in an unloaded truck is almost like using granny gear on these. I've got a Porsche Cayenne Turbo and it will selectivity determine starting from 1st based on load sensitivity, incline etc.there is a + and - on your column shifter... you can hit the minus button while driving and it will "delete" the top most gear. I am not sure how far down you can go but you can make it to where your truck never sees 10th gear
Your Porsche weighs about 4500 pounds, your tremor 8500I'm surprised there isn't any way to have the truck start from 2nd gear? I tow very little and most often it seems starting from 1st in an unloaded truck is almost like using granny gear on these. I've got a Porsche Cayenne Turbo and it will selectivity determine starting from 1st based on load sensitivity, incline etc.
I concur, pointless.this thread, man![]()
No, it's actually about 5700lbs and porsche considers them capable to tow around 7700lbs. Clearly not my F350 but not horrible.Your Porsche weighs about 4500 pounds, your tremor 8500
