High mount third brake light ground
Huck Norris
Founding Member 📜
USA
2022 F-350 Tremor
Airstream Flying Cloud 28RBQ
I searched and couldn’t find any topics. If this has been covered please point me if your search ninja foo is superior to mine.
Got a GoFastCamper and need to tie in the third brake light. Found the capped off yellow high mount light wire no problem but just can’t figure out a good grounding location. Everything I see under the truck is either 1) plastic push pins 2) hitch mounting hardware related 3) painted.
Any insight or ideas would be welcomed.
Thanks!
You can use one of the exhaust bracket bolts that’s bolts into the frame. I used one of those for rear lights.
Thanks!
If you drop the spare tire you will see a factory ground via ring terminal/lug going to the frame.
Here’s a photo of the two grounds on the driver side interior frame next to the spare tire mentioned by @BroncoHooves
Thanks! I can see one of them with the spare in place. Appreciate the help Bronco and Legmar!
