Help
MBuck17
New York
First Responder
FF
2021 F250
So when I’m driving on regular roads the truck is rough, I was just driving on the highway and every time I would hit one of those bumps that go from shoulder to median The truck would feel like it’s jumping up and then all four tires are skipping around and a slight loss of control. The truck is not leveled but it has Bilstein shocks in the front. It’s driving me crazy because I should know what it is
how many miles on it ? any Warranty left ? have you ever replaced any front end Parts ? wore out front end parts will do strange things with a small amount play and larger tires .
First thing is tire pressure. What are you running? Some run 45, I am set at 55 front and 50 rear when not towing. If towing, then run recommended (can’t recall off the top of my head- believe 70 or around there). The lower pressure will let the tires absorb more of the sharp bumps like concrete joints and such.
I’m only running 35”s and have them at 75 and 70 they are load F tires. Been running that pressure for a while and no problems. It just started out of nowhere
I have just about 12,000 miles on it with 35 inch Tera grapplers With Bilstein shocks , no level , gas
I know this thread is a couple of years old, but did you find a solution to this issue? I have a 2021 F250 Tremor and am running my 35-inch Maxxis Razer AT tires at the pressure on my door sticker 60 front and 80 rear. When I hit a patch of rough road, it feels like it is bouncing around. If I am on a curve, it almost feels like it wants to bounce out of my lane. This is a new truck to me, two weeks ago, and the tire pressure was considerably lower when I brought it home. Maybe there was a reason for that.
There is absolutely no need to run 70/80 on an unloaded truck. I have a 2021 Tremor, 6.7, run 55 front/50 rear, very smooth ride.
Thank you. I will make the adjustment before heading home today and see what that does.
I will also add I have replaced the shocks, OEM Tremor shocks are not a good or even adequate shock.
