Help With Decision. Promise it’s not run of the mill 7.3 vs 6.7!
I wish all the manufacturers these days, would build a tilt front pickup. That would make the whole servicing project vastly easier. It seems to me it could be done and still look the same as a standard pickup.
I had a water pump fail on my Ram 3500 HO with twin radiators. It also threw the belt off and destroyed it. Of course, I was 600 miles from home. These are normal maintenance items. Normally I would change the pump in an hour or two, I've done it easily on two other Rams, but I could not do it on this one. $2,000. to have a shop do it, and a tow.
All the wonderful features we've come to expect and want in trucks seem less important if they are not reliable or too hard to work on. I really want reliability.
The problem is that complexity is the enemy of reliability.
It doesn't help that many engineers are named 'Murphy'.
How can you spend in the year 2021 60K for a truck that gets 11-13 mpg? I paid 69K in 2020 and got the Tremor 6.7 that averages 17.5 mpg around town. If you haven't noticed in Biden's new war on oil prices are now 2.40 regular gas and 2.70 diesel and that's in Texas where in November of last year under Trump it was 1.60 gas and 1.80 diesel. They predicted it going even higher...
The democrats green new deal BS is trying to price us out of driving what we want!
Sorry, but Trump and Biden don't set oil prices. The Texas winter and attacks in Saudi Arabia have had a larger affect. The perception that Biden is trying to destroy the Country, as per the Trump supporters, is ridiculous. And just in case you didn't notice, gas prices were low for years before Trump became President. Or are you trying to say Trump controlled oil prices long before he became president? Gas and diesel rise together and diesel is often more expensive than gas, so four MPG less, on lower priced fuel is not going to be a deal breaker on a truck that also costs $9,500. less than the diesel version . Further, there is no such thing as the Green New Deal, or can you cite any legislation that has been passed that is called a green new deal? Let's deal with reality before panicking.
Here in Commiefornia we would kill for $2.70 diesel!
I spent $54k on a truck that ave just under 14. Don’t give the green Biden reform, we all know diesel is more regulated the gas.
At current ca prices and 13.5/17.5 mpg you’re looking $11k savings after 200k miles. Good thing you only spent $15k more for the diesel truck...
We each do have our own list. My list is influenced from being a diesel mechanic and having three Cummins and a Ford diesel. I am biased against Ford diesels after having spent $5,000. to get one to 100,000 miles, with two new cylinder heads and an injection pump. And having watched the warrantee disaster Ford faced with the 6.0, and the 6.4. And knowing that the cab has to come off to do many of the repairs that are likely with a higher mileage truck. All three of my Cummins engines were easy to work on and flawless in a total of about 600,000 miles.
Diesels are great to drive, the torque is wonderful when towing a heavy trailer, and the mileage makes long trips more enjoyable.
The cons are the initial cost (not a deal breaker by itself), the extra weight up front (worse handling off road and harder to get unstuck), and the constant concern that it will be nearly impossible to work on likely failure points. A bad load of fuel could cost $8-12,000. and require the removal of the cab, whereas a whole new crate 7.3 engine can be purchased, including shipping, for $8,100. ready to drop in and go. The biggest con on the 6.7 to me is not being able to work on it. On the 7.3 the water pump, alternators, throttle body, serpentine belt, and spark plugs can all be reached by just opening the hood and reaching in.
I'm not planning to sell this truck, meaning I will be facing repair issues eventually.
The 7.3 is not a typical gasser, in that is does not have to rev to the moon to pull hard, it gets remarkable mileage for a gas engine. Mine only has 438 miles on it and is not broken in, but I have averaged 15 MPG so far. That is great for a 6,000 lb gas driven truck. And it has lots of power. I climbed over an 8,000' pass yesterday and it dropped to 8th gear and cruised along at 65 MPH at about 2100 RPM. 70 in 10th is only 1900 RPM. First is really low and it will easily spin the tires. No problem getting load moving.
Bottom line, the diesel has better torque and gets better mileage, but the 7.3 is better in every other way. I'm a diesel guy, but I bought the 7.3. Buying the 6.7 means you are taking the risk that you will never need to work on it, or accepting that if it breaks down, or you get a bad load of fuel, probably only Ford will be equipped to pull the cab off to fix it. The cab removal is 10-12 hours at full shop rates, so about $2,000. added to repairs. And everything associated with the cab, wiring, steering, pedal linkages, etc, gets disturbed in the process.
If you get one, buy the warrantee too, and don't let it expire. Be sure the warrantee says it will cover the DPF, and doesn't just consider that a filter that is not covered.
Before you decide you have to have a 6.7, go test drive a 7.3 in an F250. Pretty nice.
Thank you!
If I remember correctly, Californians voted to tax themselves more on fuel, and they voted for a governor that wants to improve the environment. What part of that is communism? You were able to vote, and you got what you voted for. That's democracy.
So if people vote in communism it’s would then be called democracy? Haha. That’s assuming the voting was unrestricted.
So if people vote in communism it’s would then be called democracy? Haha. That’s assuming the voting was uninstructed....
It's not phony labels that mean anything. People can vote in anyone they want. Democracy is a system where the people govern themselves and vote in representatives to do their business. Power from the bottom up. Communism is a system of government, that never lives up to its ideals. It sounds good on paper, but doesn't work very well. Too many people decide that as soon as they don't like a government policy, it must be communism, but it's not. If everyone could simply ignore any rules they don't like, we would simply be animals living in caves. Government is simply a way to work together for the common good. it's human nature and corruption that destroy the concept by being power hungry and not representing the people that sent them to Washington. With over 350,000,000 million people trying to live in a common country, there has to be compromise and many who are not happy. Democracy means you can stand up and make your case for a better system, a better plan, or a better law. If you have a case, your story will ring with the voters, and if you don't like the system, you can move to a better country. Screaming Communisn! at rules you don't like means nothing, it is not constructive and it does not make anything better.
It’s nice to be talked down upon ca politics by those that live outside of ca. And you may say that it’s a phony label, ca is more and more like the ccp run China each and every day. But as you say that’s the fault of the ca constituents that vote in these asinine rules and regulators. I have just 2 points to make on ca politics.
1. There is a vast number here would want to live in communistic society all while living on the prosperity of capitalism. That is they will not live in Cuba or Valenzuela.
2. Those in charge choose a lot more of the states policies than the voters will ever know. And this my friend is not democracy.
I will add a caveat: Yes we are still free to move out any time we want. I’m exploring my options right now.
If California Democrats are so great then explain why the state has been on a steady decline since 1956? Since then the state legislature has been continuously 'blessed' by a Democrat majority with the exception of 6 years. California now enjoys the highest poverty rate in the nation by far when corrected for cost of living - over 24%! No other state is close. It has the worst business environment by any metric as demonstrated by Tesla leaving. Only 5% pay state income tax. The high earner retirees who are leaving are being replaced by more low income types who come for the free. The state is on the hook for a huge pension liability that grows faster than it is funded. The demographics are brutally obvious - it's not going to be pretty.
Thanks for pointing out that my opinion is not valid because I don't live in CA. You are partly correct. I lived in CA for over 60 years, ran a very successful business there, for forty years, that I started. I studied China's system and visited there five times to see it first hand. I understand how to do business there and how the system works. I also ran for public office in the US and know a bit about the inner workings of our system too. The things I never do are play the victim, blame others for things I don't understand, or apply buzzwords and false labels to things I don't understand. You can play it any way you wish, but just because you don't like the policies, doesn't mean it's communism. I'm afraid you have no idea what that word means, or how useless it is to yell it when you are unhappy. You live in America, so stand up and make your case for better policies. Articulate what they are. Make your case. That is democracy. Whining is not. Blaming is not. And yes, the people are in charge in America. They can and will keep making the same mistakes over and over until they see the light. They can vote in anyone they like. They can change the Constitution if they wish. And you are always free to move, just like I did, if you want to.
BTW, you have a very nice looking truck. Looks somehow familiar.
Maybe you can explain who said Democrats are so great. I missed that. Please show me who said that.
It’s solid just back of mind watching the videos of people poking holes in the rubber undercoating years later because it wasn’t applied right etc, plus a few interior things my current truck doesn’t have that I would enjoy. So my thought of spending 5k to get the suspension, skid plates etc or just cutting ties and spending a little more for brand new no mods needed is what bounces back and forth in my head.
Thanks!
Yet you left.....just like my friend recently did after he ran a successful business here for years. The increased regulations put on ca and its citizens by those above our pay grade is astonishing. Really my only question is(don’t answer as it’s rhetorical to mainly have others in this thread think for themselves) when do you call Valenzuela communist?
Our Republic is only as good as those in charge. It’s slowly slipping away from ca and all states, it’s a sad sight to see. It starts slowly but then it’s gone. It goes way faster than anyone wants to believe. I agree with Loshad when he states the loss of our freedoms here in ca have a communistic flavor. And I agree you are correct as our justice system does not have 99% guilty verdicts....do we really want to head in that direction?
Yes your truck is stunning!
Yes I’m done with the politics....
And now back to our regularly scheduled programming..........
I am so impressed by how refined this new truck is. Do you guys think the extended Ford warrantee is the right choice? I went with it after working on the price of it.
I love it all you X Californians turn this place into a shit hole and then jump ship probably voted for all this great stuff for the past 60 years now your Nevada tax free helping turn Nevada blue
