Help deciding between FOX 2.5HTO, FOX Performance elite 2.5 or King 2.5
I have about 5K on my pintops and for my driving and terrain, I think the pathfinders will be a better fit. Anyone interested in the pintops? They are 2.5" and in excellent condition. Located in colorado
Diesel or gas?
My truck came with Pintops and I do love the ride, but I dont off road alot and was wondering if the Pathfinders were better for how I drive the truck.
If you tow and haul allot, I think you’ll like the pathfinders. If not and you don’t off-road, the pathfinders will be smoother on the road… it will ride better for your application.
Are what worth $1000 more than king 2.5s?
The Pathfinder series from Carli is cheaper than their King 2.5 based pintop kit, and it offers better handling on road. It also will hold up much better to salt / corrosion. If you factor either PPF or paint for the King 2.5s to support the exterior finish on those fancy shocks, the difference is even greater.
I will die on the Pintop hill because I love my truck and @BLACKCHERRY did an insane job with our shocks, but the Pathfinders have become a new fav for clients.
G
I’m with you brother, nothing but pintops for me… i absolutely love the carli pintop suspension set up with full progressive leaf springs.
I had just decided to go with the HTO just before my car accident but after talking with @BLACKCHERRY I’ve decided to go with the full Pathfinder. I really appreciate all of the time he spent explaining everything to me.
It can be expensive for sure but my attorney was able to get me a better depreciated value check so that makes the decision easier.
I installed the full Pathfinder on mine recently, the rear springs with the XL option (800-1200lb extra bed weight), and the ride difference is night and day.
I'm certain you will be happy with the choice.
How does it ride empty with those 800# leafs vs the stock leafs?
So I am telling the whole story, I will also mention that I have long travel air bags holding 5 psi as well as the heavier leafs.
I am riding currently with about 400 or so lbs constant in the rear. That has to be taken into consideration for this discussion.
That said, the upgraded leafs are far more compliant than stock leafs. Combined with the pathfinder shocks (I see now how everything works together) the ride is just an incredible difference from stock. Words really can't do it justice.
I'm trying to avoid hyperbole or sound like a Carli fan boy or somehow justify my spending on the kit... however, this is not some "small but noticeable" improvement. It's an altogether different world in the ride department. It's almost like a high end half ton ride while maintaining the HD capabilities.
I can enthusiastically recommend the pathfinder. It's everything that it's marketed to be.
Coming from the world of Raptors (Gen1 through Gen 3) I didn't buy this truck to be a replicate of a Raptor, but definitely am interested in some type of shock to improve offroading in terms of bumpy trails and then maybe a tad smoother on road. Truck would be 80% pavement, 10% offroading-and preferably not crawling and then 10% 6k dry weight travel trailer.
At first, I was debating a full Carli kit, but at the same time don't want to go down the suspension rabbit hole of wanting one item, but then it requires x y and z to work. And then their website starts at 5k, then can quickly hit 11k lol.
Want to keep the tire size to 35, so not really wanting to lift the truck that much.
The 2.5's Elites seem cheap to me after years of Raptor "tax" but just don't want to dump 3.5k to get only a minor improvement even adjusting the High/low compression but then needing new springs and leafs etc.
Budget for this truck isn't tight, mainly bought the 7.3L to whipple down the line, but just don't want to burn money on items that don't really "pay off"
What I will say, speaking from experience, is that the shocks will only provide a slight amount of improvement. On the front, the Carli swaybar makes a huge difference and knocks down that side to side thrashing. On the rear, there's just no real getting past the stiff spring rate. Good shocks will help, but not nearly what you are hoping for. Just an opinion....
I appreciate the thoughts. Definitely want to make sure the money goes to good use.
3.5k isn't nothing to sneeze on.
Rather buy once cry once so if a kit like Carli is something I just need to review more for my wants than maybe that's better than just swapping one item, when multiple are needed for my wants
I went 2.5 HTO...its a work truck and I treat it like it....couldn't tell last time it was washed...They are better than stock for sure.
FWIW while I'm deciding on carli kits found an open box 2.5 elites for a really good price.
Still playing with settings, but the initial harshness has been reduced, and now I can hit those big speed bumps and it soaks it up up to 40-45 mph when before the speed limit was 30 for the bumps and you felt the bumps pretty good.
