Harbor Freight Road Shock 4-LED Reflector Covers
OK
2022 F250 7.3L
1988 Yamaha Big Bear 350
New product from OmahaBravo Designs
Reflector covers for the Harbor Freight RoadShock Edge 4-LED off-road lights. When mounted as ditch lights, the side LEDs can be distracting/bothersome for both driver and passengers. These 3d printed, UV-resistant reflector covers block the side leds from being a nuisance and/or safety issue.
They mount between the lens and housing using friction and strategic design to firmly hold them in place without the need for adhesives. This allows for accurate but easy installation as well as simple removal should the need arise. They are low-profile and do not hinder the use of the Rock Guard or Amber Lens that comes with each light.
Plates are 3d printed using uv and weather-resistant ASA filament. Two reflector covers per package: one pass side, one driver side.
You can find these on my website: omahabravodesigns.com
Damn that's impressive work. :love: Props to your skill set.
Did you stop making these?
Of that style, I did. Those lights get way too hot to put anything against the lens.
I've redesigned them and am printing them out of PPA-CF, a super high temp filament. I'm struggling getting them to print. Once I can figure that out, i'll make them available.
Appreciate the update. Thinking about using these on my son's car for A-pillars.
I have them on my pickup. I'm happy with them although one has moisture ingress and the other doesnt.
The side-throws put out a lot more light than i expected which is why i'm glad i have my covers on them. I've never ran them without but i can imagine that pass side being super annoying if it wasnt covered.
I have a Bambu Lab P1S printer that I think can handle that filament... let me know if I can help.
Appreciate the offer, Mike.
Just need to tweak my settings so it turns out good, is all.
Recalibrating seemed to do the trick!
Just need to test how well these work since the flat is back (for printing purposes).
Had quite a few hit me up about these recently. Glad to be making some meaningful progress
How long have you had them?
Not sure how i missed your comment... my bad.
I've had them on my truck for 4-5 months. Still cant get that pass side to seal up enough to not get some moisture. Thinking about 3d printing a super thin TPU gasket for it but haven't gotten to it yet.
I did not see anybody ask, maybe i missed it, but do you know if this cover will also work on their Roadshock Edge 6 pod which looks nearly the same at least at the sides.
It wont. The 6 has a larger more rectangular opening. Might be doable but havent looked into it yet.
I actually just did some research and discovered that while Edge 6 might not be as luminous as bd lp6, it certainly has a better (almost 180 degree) spread wide pattern that no other pod seems to match.
this is interesting.
I wish they offered a complete flood lens for the 4. I have the spot/flood and the spots are super spotty. Granted, these are the first lights i've ever installed on a truck but i dont remember my buddies LP4s having the bright spots.
Thanks. I ended up buying a set of these to mount on the bumper of my wife's JL Rubicon and I feel they are way too big for the A-pillar of my son's GX460. I'll have keep an eye on them for moisture.
Curios, where did you install them? Is the flood not a hood glare issue if they are pillar lights?
I’m actually leaning towards complete spot lens Edge 4 pods now because i’m thinking that as A pillar ditch light the flood pattern might actually cause hood glare, whereas spots will not. And given the same 180 degree side spread in these Edge4 lights they are perfect for side illumination. And your covers will take care of internal side glare….
This is what it looks like. NOTE: this was before they were aimed.
These are the Spot/Flood 4LED HF lights sitting on BAM mounts mounted to SDHQ a-pillar mounts.
I am running this exact set up; same lights, mounts and side reflector covers from Omaha Bravo. They throw a ton of light and with the reflector covers, I have zero hood reflection issues. I am extremely happy with the set up.
