Ham and CB radio mounted
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
Had my rig there for 5.5 years, still works great, only issue is the led lights on the channel indicator slightly fade out in the heat of the day sitting in a closed vehicle, after awhile the leds brighten back up once a/c kicks in.
The CB on the top gets pretty warm, you are right. But it seems to be working alright. Never gets too hot to hold your hand on it. I was thinking about modifying the mount to cover the top of the CB with a sun visor type of shield but I think I will hold off unless there is a problem.
The ICOM below it is just the front panel mounted onto a 3D printed base with a remote speaker inside. The ICOM doesn't get warm at all.
This is what the mount looks like.
Very cool! Might consider doing the same in my truck, then. Definitely an ideal spot from a usability standpoint.
And that's a sweet mount!
I got my power from my upfitter switch, if on the cell I can just hit the upfitter switch and kill the radar detector and CB at the same time If CB or detector go off. Both are wire to one stitch, very clean install.
It took several tries to get the mount just right so that the face of the radio was at the right angle in a good position. A big problem I had was that the CB has it's speaker on the bottom. So if it sits on the top you can't hear it unless there is some opening for the sound. That is what the big void in the center of the mount is for. Also the speaker for the ICOM is mounted on the back pointing forward into the same void as the CB speaker. The sound exits out the sides and bottom.
Thought about going on the dash, but ended up going with the head on the overhead console. Was worried about the heat beating down on the radios during the summer, along with the high visibility for theft. The morons around here break into cars for much less than a radio on the dash these days. :mad:
Ran wires for head unit and a dashcam down drivers pillar, radio body mounted on the rear wall behind the passenger rear seat. Added an external speaker under the drivers seat. Mic next to drivers seat within easy reach.
@Parksoffroad love the head unit mount! Wondering if you have any more details of the mounting itself.
How did you get into the overhead console? Does it just pull down from the headliner, or did you have to drop the whole headliner?
What is the controller hanging off of/mounted to? Is there significant structure in the overhead console?
I need to mount two faceplates and thinking I might do what you did, but have them to the left and right of each other.
You might think about using a “goose neck” attached to the passenger seat for the head unit.
Oh that’s interesting! Definitely more intrusive in the passenger compartment, but no question it would be a simpler install. And easily handles both faceplates and handsets. Heck, could expand to my CB radio I’ll have installed as well
(Currently thinking the CB will be one where all the controls are in the handset, so no faceplate to mount, but still need to put the handset somewhere.)
I mount my microphone on the other side of the steering column to the start button
That’s slick, except I’m going to have 3 handsets to position. So I love it, but don’t think it will really serve my needs.
One thing I did just learn. My VHF radio for Search and Rescue has an optional handset that acts as a full control unit. Has a display and fully replaces the normal faceplate. That could be a lot easier to mount in the truck.
I have friends wanting me to get an amateur radio license. Because it’s HF if I was to go that route and get a Codan, I was thinking of mounting it away from the drivers seat somewhere. It’s not going to be a radio I’ll be using to chat whilst driving, so I’d put somewhere else to reduce clutter. Maybe even in the tray-I have a canopy-where it would be easy to connect the aerial. Just an idea, and looking to see what others do. We have a flying doctor service for the outback (RFDS) and they have their own frequency that you can use in an emergency.
Just be sure that's the same one. The handle is black on that link - red on the one @maxspongebob posted. Like this, https://www.lowes.com/pd/CRAFTSMAN-DIY-13-in-Red-Plastic-Lockable-Tool-Box/1000578381
I will have to keep my eyeballs out for a set.
True but the pics in the post don’t look 13” to me. Could be just a color change for the same box. My eyeball tape measure is telling me those are 16 as the 13 only has two hinges and the 16 has three as in the original posts pictures. Also the 13” has 12 squares across the top. The 16 has 14 like the original picture. I could be wrong but I’m relatively sure it’s the 16”.
Good catch!
Curious what tool boxes are those your using for underwater storage? They fit perfectly.
