Been doing some light reading and research.
I was curious to see if the base of their regular hex lugs (part #14150BGR) had a different size (larger) base to them. From what I’ve found it appears they do. The splined lugs have a base bump out measurement of around .915” and from research the hex lugs have a base bump out width of 1.06” it’s about an 1/8” difference but that’ll give you a little bit of a wider taper to grab onto with the clips on the covers.
Regular hex lugs
20 pack with Key14x1.5 thread pattern Duplex Tuner Lug Set
shop.wheelacc.com
For reference the base of the stock lug where the cover snaps over is around 1.2”.
So really with the conical adapter/washer it opens up finding a reputable lug that has that base dimension of around 1.2” and you won’t even need to mess with the tabs for the wheel cover.
