GM and Allison call it quits.
SO a couple called it quits.....the tranny is searching for a new bo.....SO how does all this change my life?? It's a trick question......Nothing for me is changing.
I for one don't chase this BS about a manufacturer's product name badge (engine or transmission) as to be the WHOLE reason to buy a truck. If Allison badges turn up on a Super Duty.....whatever.....I could care less. Does the truck work/operate as I want....then good. If there's some HUGE amount of issues would I be leery to buy.......yep, sure but I'm all about learning about problems THEN figuring out the best solutions.
Some people just want to complain....some just want the problem solved. Be part of the solution, don't become part of the sheep making a problem worse cause you got butt hurt.
Yes, there are times when the SD 10spd does act "weird" to me.....but then I realize it's WHAT I DID to the input to make it wonky. I've long tried to find someone with these "shifting" issues close to me so I could ask for a ride-along. I want to feel what they are experiencing. Not because I think they are being a p-$$y....but I want to understand their experience while driving.
People will describe a shifting problem as "...feels like the truck got rear ended by another car..". I can tell you....my 9,000lb truck getting rear ended needs QUITE a bit of force to make it horrible feeling. I got hit in my 2006 in a low-speed incident, I had to ask my wife "Did we just get hit?", other driver lady had to have her car towed, I drove home.
I can say this 100%....There's going to be problems with any brand regardless of name/badge on the hood. IF you are the problem as in how you are driving it are YOU going to admit YOU are the problem????????? Nah....not likely.
Thanks for reading this far.....Good luck with your dreams and choices. 😜 😜 🤣 🤣 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲
The document above literally says they built 1,000,000+ Duramax's in an Izuzu engine plant. Sure it's a joint venture, which I'm sure covered design and quality standards for production, but Izuzu did some pretty heavy lifting for it.
company dmax ltd built them. Isuzu had a hand in it as did gm, yes some Isuzu parts were used. But no, Isuzu didn’t manufacture the duramax and sell them to gm like the ram/cummins relationship.
The Duramax V8 engine is a family of 6.6-liter diesel V8 engines produced by DMAX, a wholly owned subsidiary of General Motors in Moraine, Ohio.
That is true as of 2022, but I can go change that to 2085 if I wanted to.
Now you bring up DMAX Ltd? had to google a little? no one said sell them to GM. They teamed up with Isuzu to design the engine for them, It's an Isuzu. Go look at your Duramax engine plate. If it's prior to 2022 it's says Isuzu, some time after it says GM, NEVER said DMAX Ltd as that is the joint venture company and manufacturing plant. The high pressure common rail is what GM wanted from Isuzu and that changed the diesel world forever. You can try and split hairs and if you did the IUE-CWA actually built the motors.
