Well I just got bit by this... my truck has been having all sorts of electrical gremlins for a couple of years now. Shame on me for not taking the truck to Ford sooner but the issues I was seeing were so "out there" that I wasn't correlating this all back to the BJB (Battery Junction Box). This weekend I started doing some research and came across the same TSB posted above and that's when I went to Ford and spoke to a diesel tech there who told me he's probably replaced 30+ BJBs on the 2020+ Super Duty's and it's all because of water intrusion. It's a common enough issue that my local Ford store stocks up on spare Gas (B)/Diesel (A) versions.
Well my issue came to a head last Friday when after a 2nd time in about a month the batteries which are new (replaced after the first incident) were "Dead dead"... like sitting at 4v dead... Truck sat for 3 days but on the 2nd day it rained hard almost all day and in the morning the truck was so dead it needed a truck and another battery booster box to get it to crank.... but once it cranked all sorts of other issues happened like my DEF system threw a fault... I hooked up Forscan to the truck and all sorts of DTCs were lit up and I couldn't clear many of the faults so it was time to address it with Ford. I picked up the replacement BJB for my Diesel this morning and did the swap out... took me about 3 hrs (Ford only pays techs .6hrs if this were under warranty)... After buttoning everything up, the truck is happy as can be. It's a $350 part + tax.
I was a little worried that I had a different issue because when I first removed the BJB cover, there didn't appear to be any signs of water intrusion as I've seen other's picture postings of their fuse panel which looked much worse... mine looked super clean in comparison but once it took everything apart down to the circuit board, that's when I saw the extensive damage to all the circuitry, the board was all corroded. Definitely a situation where water enters from the top and not the bottom.
Ford should've made a small gasket for the lid similar to what they did on the low pressure fuel filter that just makes a liquid tight seal. I haven't figured out yet how I'm going to prevent this from happening again because the Ford tech I spoke to says even a properly installed lid won't keep water out when experience heavy water draining as the water just pours on top of the lid and runs down the side and into the channel where the top lid and bottom case meet.
Here's some pics of the top fuse panel and board itself all corroded.
I strongly recommend if any of y'all have a truck acting "drunk" ever with electrical issues ( horn wont work or stays on, can't turn off the truck, batteries dying, weird faults detected when you check via a scan tool, etc... this is very likely your issue and it's covered under the B2B warranty and nothing else.
This is what the top of my panel looks like (old one)... pretty good right...
On the bottom side things looks pretty good but I noticed a small spot had some corrosion. So I took out all the fuses....
And this is what I found inside... basically a corroded mess.
This is the part # for the Diesel's BTW... the same part # ending in B is what you need for a gasser.
Unfortunately this issue needs more attention as Ford isn't doing their part to make us whole on this one by recalling and replacing these lids that don't seal well. I checked on mine and it's always been properly seated hence the panel on the top looked so clean... but my Diesel Ford tech assured me that unless I proactively "seal" the lid on to the base somehow, that I'm likely to experience future gremlins.
