didn't see it mentioned
4x4 mode high & low should be engaged often. once a month minimum.
i do it in my driveway, just enough to know it engaged in a straight line. drive about 30ft forward & backward.
disengage, drive the length of the drive, 30ft or so then turning out of the drive i know it's all back to rear wheel only.
if it drags & lunges i back up my driveway & then forward to let it disengage, staying as straight as i can through the process.
also, even if you don't feel the rear locker drag & lunge, don't test it turning on dry pavement either. it's doing the same thing.
good to know your limited-slip is working. it'll come in handy when/if you need it. just, don't tear it up on dry pavement. that'd be a bummer!!!
