Front Limited Slip Chatter ???
stufarmer
Tremor Addict
Founding Member 📜
Tampa
Air Force
21' Tremor .. 20' Lincoln Continental
I'm confused. ??
In 2WD, with the Ft Hubs Locked or Unlocked, my 21' has developed a Clicking/Popping sounds from the Front Diff when I make Left or Right turns, the Sound seems to be much louder on tighter Left turns. These sounds started at around 10,000 miles and have only gotten louder. I'm currently at 15,000. My dealer just replaced both outer 1/2 shafts and U Joints and the sound is still there. Could the Front Limited Slip be making these sounds ..?? It does require Limited Slip-Friction Reducer additive, but I've never heard this sound so soon and so loud before. What do ya think ..
In 2wd with the hubs unlocked the front diff should NOT be turning at all as I understand it. It is disconnected from the front wheels because the hubs are unlocked and the transfer case being in 2wd should not be sending power to the front axle either.
So IMO, that should eliminate the limited slip diff from the equation.
Any play in the hub bearings?
That's pretty strange - and it sounds like you're on the process of elimination train. You're confident it's the dif and not a steering/suspension component - you could lay under the truck while someone turns the wheel back and forth - while it's in park - and keep safe from all the dangers - yada yada. Or does it ONLY do it while driving?
This may sound odd - but your lug nuts are torqued to spec, right?
It only does it while I'm driving. Hubs locked, or unlocked, it makes this clicking/popping sound only in turns. Every rotation of the Tire it'll make the sound. I agreed with the mechanic that it sounded like the outer U Joint was binding in turns. That wasn't it, he replaced both sides.
This sounds more like a wheel bearing to me. However, I know there's an issue with the vacuum locking hubs. Something about them sticking. When I took my 250 in for clicking noises the first thing the guy did was lock then unlock the hubs. It didn't help as my click was the shocks. But given his immediate gravitation to the procedure I'd suggest trying it.
Above statements are correct. The front diff carrier is completely at rest when the hubs are unlocked and you're in 2wd. All three shafts to the differential are disconnected; two hubs and the front drive shaft. Unless a hub is locking in unintentionally there's basically zero chance this is the front diff.
I toggle in and out of 4wd every day on my gravel driveway. Haven’t noticed any strange noises turning through switchbacks in 2 or 4wd. I would check wheels, brakes, hubs, and bearings in that order. But of course all of that would have been apart with u-joints replaced. Hmm. Check front end like Vmonster said, and check it all while on jacks, turning it while spinning wheels. It sounds like something simple, I wonder if it does have to do with the vacuum hub locking system. I’ve seen it said that the wheel has to rotate a turn for the auto hub to engage. Following…
I think i'll order a set of Warn Locking Hubs. That way, I'll get rid of the Vacuum Hubs altogether. I can only hope it helps, because they changed everything on both sides. Thanks for all your input ..
changing the hubs wont fix the wheel bearings if that is the issue.
I would get those checked first before I spent $500+ of my own cash.
It sounds like your dealer is aware of the issue and willing to work through it. I would throw it back in their laps and make them fix it. The minute you go trying to "fix it on your own" and then take it back they may or may not be as willing to work on it.
Totally agree.
I lifted the Lt Ft wheel off the ground and used a Mechanics Stethoscope to listen to the bearing, nothing unusual. Of course thats not under the load, same with the Hub, nothing unusual. I might do a Diff fluid Change and use Amsoil Severe Gear with the proper amount of L/S Additive this weekend. Maybe what I'm hearing is Clutch Chatter from the Diff because of a lack of L/S additive from the Factory ..??
If I see anything in the Diff Fluid I'll take photos.
Thanks again for your input ..
If you are in 2wd in the transfer case and the hubs are truly unlocked, your front diff is NOT TURNING...
So again, if everything is as it should be, your diff is not turning and you are NOT hearing clutch noise...
Question: when you guys talk about hubs Locked or Unlocked, what do you mean because my hubs say Auto and Lock. Is mine different being a Plat or does Auto mean unlocked for this discussion??? Thanks.
auto, in 2wd, which is what the OP says he is in, means unlocked...
I'm confused. ??
Dude, I think you are experiencing the same thing mine does. I honestly thought it was a brake pad, because when it first started happening it would click only on first drive in the morning when I first tapped the breaks coming out of my development. Dealer said pads were fine and that "these trucks normally click and pop all the time", which seemed like a bullshit answer to me but it was free tune-up so whatever.
I found when I had the Transfer Case in 2WD, and the Hubs in the Locked position, when making sharp Left or Right turn the front Limited Slip tried to lock the Differential. When I Unlock the Hubs the sound and feel went away. That was the ratcheting I heard and felt. I happen to be the first Tremor owner with this complaint at my dealership.
Super interesting! Thanks for sharing the outcome.
As an aside, what’s the benefit of running them in the locked position? Just in case a vacuum line breaks?
Keeps the front diff lubed up more.
Wow - had no idea. That’s pretty interesting. I need to understand that set-up more. I never have mine in lock unless the SHTF with road conditions or something.
