how much of the center support needed to be removed ?The “brackets” I used at 5” long pieces of 1.5” aluminum angle. I just used some random 1-1/4” timber tech screws mounted into the plastic/fiberglass supports, then drilled two holes for the light bar attachment screws. I used a dremel with a burr bit below the light bar so it would line up with the grill. I would burr a little plastic off, tape the light bar in place, then fit the grill back over until the light bar lined up perfectly in the grill opening. Then attach the brackets.
