New to the group. Just picked up my 2022 F250 Platinum Tremor and searching for lighting options. Any suggestions or advice for a lightbar that would fit the front bumper/grille area?
Very nicely done! Looks great.I'm sure someone has done this already but I did a lot of looking and found nothing. 30" curved SR rigid light bar mounted behind the grill. I had originally bought KD bumper brackets to install but I really wanted the bar behind the grill for security reasons. I removed the grill, cut out a little of the plastic/fiberglass vertical support member to accommodate the depth of the bar and built some brackets out of aluminum 1.5" angle.View attachment 37798
followingI like that. So much cleaner than putting it on top of the bumper. Would you mind posting some pics of the brackets you came up with to mount it?
This is a nice set-up. I like it behind the grill, as well.I'm sure someone has done this already but I did a lot of looking and found nothing. 30" curved SR rigid light bar mounted behind the grill. I had originally bought KD bumper brackets to install but I really wanted the bar behind the grill for security reasons. I removed the grill, cut out a little of the plastic/fiberglass vertical support member to accommodate the depth of the bar and built some brackets out of aluminum 1.5" angle.View attachment 37798
The “brackets” I used at 5” long pieces of 1.5” aluminum angle. I just used some random 1-1/4” timber tech screws mounted into the plastic/fiberglass supports, then drilled two holes for the light bar attachment screws. I used a dremel with a burr bit below the light bar so it would line up with the grill. I would burr a little plastic off, tape the light bar in place, then fit the grill back over until the light bar lined up perfectly in the grill opening. Then attach the brackets.
I will be looking to put a light bar is were the wench goes. Here is AZ no front plate is required.
Lights in the grill ? I read on this site about transmissions running hot and weight of trailers towed . Then I see lights installed in the grill of the truck and think why would I cut off any air supply that possibly could be feeding radiators or items need to be kept cool by movement of air . Don't want to rain on anyone's parade but it does not make sense .
THAT'S JUST GREAT, NOW I WANT ONE DAMMIT. THANKS FOR POSTING!!!!!!I'm sure someone has done this already but I did a lot of looking and found nothing. 30" curved SR rigid light bar mounted behind the grill. I had originally bought KD bumper brackets to install but I really wanted the bar behind the grill for security reasons. I removed the grill, cut out a little of the plastic/fiberglass vertical support member to accommodate the depth of the bar and built some brackets out of aluminum 1.5" angle.View attachment 37798
When you get a chance can you please post a photo of these turned on? Looks great, thanksI'm sure someone has done this already but I did a lot of looking and found nothing. 30" curved SR rigid light bar mounted behind the grill. I had originally bought KD bumper brackets to install but I really wanted the bar behind the grill for security reasons. I removed the grill, cut out a little of the plastic/fiberglass vertical support member to accommodate the depth of the bar and built some brackets out of aluminum 1.5" angle.View attachment 37798
