Front Fender liners
Definitely do the factory plastic fronts and best to do it when you order the truck. I'm not sure the reasoning behind the standard felt ones but I can't imagine trying to clean them.
While you're at it, make sure you install the rear ones. Nothing looks worse than seeing a painted body in the wheel arch or seeing daylight.
Also while you're at it, get the vinyl floors :D
my local line-x will spray the same coating they use in the bed inside your rear fenderwells... looks great and holds up just as good as the bedliner does
