Front diferential fail
If it is a gear issue I would want the entire front end replaced...not saying they can't but installing gears probably doesn't happen everyday in dealership especially on Dana axels...you have to put the carrier back in the housing to check backlash...I have regeared a couple smaller Dana axels it's a tedious PIA job unless you get your shims right on the first try...I have never been that lucky.
Thank you!
When in 2wd the t-case is not sending power to the front diff, otherwise, simply putting our hubs in "lock" would put us in 4wd, this is not the case.
Agree, correct. None of the front end components are spinning unless you either lock the hubs (manually turn to lock), or shift into 4WD, with the knob, which then shifts the transfer case into 4x4 and activates the vacuum solenoid to send vacuum to the hubs and lock them in. I have not researched much into these new transfer cases, but assume they have synchronization rings to bring the front end up to speed as it shifts - allowing the shift on the fly ability.
Something doesn't add up here.
OP took it in for a squeal. No grinding, no clunking, no vibration, no indication that the 4wd doesn't function and the dealer says its junk??
I don't doubt the OP's symptom but I highly doubt the dealers diagnosis....
What do you mean by OP?
2022 Tremor 7.3 12,000 mi.
While hunting in Utah on snowy road. 20-25 mph in 4wd. Noticed squealing sound from front left wheel like a bearing noise or like when brake wear indicator starts making noise. Only in 4wd. Got it back to dealer, discovered copious metal in front diff oil. Want to replace ring and pinion. Parts arr not available and need to be manufactured. Have no idea how long this will take. I have the truck back, can drive but not in 4wd. Anyone no of sny with this problem, or, any insight is welcome. Thx! Tominatorp
Okay, so, I just got the truck back from Ford. I have to regress. First diagnosis after using”chassis ear” they “pinpointed” noise at front Left wheel hub area. Determined binding in hub lock assembly and replaced. Still had same noise. Then, determined now, noise is in front differential. Inspected, found metal. Replaced ring and pinion and all associated bearings, seals etc. said they found outer pinion bearing “pitted” and that was consistent with the excessive metal found.
He told me noise was now gone. I test drive. In 4WD Wheel is still making a “rotating kinda metal rubbing sound” from fr..left wheel, very similar to the original sound, except that was more of a squeal like a bearing noise.
My Question : Does anyone hear a similar noise in their truck while in 4WD? Doesn’t matter if hubs are locked or not. It’s more prevalent with a little back pressure when you let off the gas, but still there otherwise.
I would expect a little noise from a 4WD, but this is very similar to the original noise, and have never experienced it before with 2 other previous Ford 4wd’s. appreciate you guys’ feed back, this forum is awesome!. Thx Again!
Closely watching for further updates. I don't run in 4WD enough to have had the issue. The video of the failed seal was really good.
hub bearing/seal?
there is a good video on youtube of mechanic replacing one. the truck had a similar noise to what you are describing
Up here in northern B.C. I run in 4 wheel drive for months in the winter. A few weeks ago as I approach up my driveway at slow speed I hear a left front quiet squeak type sound. Long story short the ford mechanics diagnosed just like the previous video my 2020 needed and reciecved new sel. After that was done the test drive with chassi ear took them over and replaced my right seal also. All good now. covered by warranty. All the different superduties with all the miles in 4 wheel drive I never had that issue. I have 25,000 miles on this 2020 thru esentially 4 winters. Makes me wonder
