Front diferential fail
Tominator
Tremor Buff
Concord, Ca.
‘22 Tremor 7.3 gas
2022 Tremor 7.3 12,000 mi.
While hunting in Utah on snowy road. 20-25 mph in 4wd. Noticed squealing sound from front left wheel like a bearing noise or like when brake wear indicator starts making noise. Only in 4wd. Got it back to dealer, discovered copious metal in front diff oil. Want to replace ring and pinion. Parts arr not available and need to be manufactured. Have no idea how long this will take. I have the truck back, can drive but not in 4wd. Anyone no of sny with this problem, or, any insight is welcome. Thx! Tominatorp
Just swap in a Tru-Trac. I realize that means you dish out cash. I find it VERY odd any dealership would know parts need to be "manufactured" to cover a warranty item. (??) Just cause something may show 0 stock doesn't mean there's NONE to order into the system that are on the manufacturer's shelf.
What’s bad is what happened, I have driven my f350 from Kansas all the way the way to Maine in 4 H in a snow storm and then numerous other times for extremely long duration and not one problem. when you looked at the ring and pinion did it show wear? how were the bearings in the axle housing shafts? Was there a leak at the pinion or the end of shafts or anywhere? Just curious
Sounds like a Walmart employee excuse. Trying to keep from having to do their actual job and find the damn thing
I wasn't going to say it that way...but you covered it. :ROFLMAO: :ROFLMAO:
So what actually is the root cause of the failure. Did they give you any insight??
Aftermarket companies sell gears for these trucks every day. May not be for parts, but they work just the same. Personally, id find a good 4x4 shop and have them take a look
Yeah this is all fresh, i’ll talk to the mgr tomorrow. I will get a second opinion, but warranty is probably the issue
I don’t think they have determined that exactly. I’m wndering why i’m hearing a squeal from the left wheel an dit’s the differential? I guess the metal can only be from the diff. Housing area? This is all fresh I’m talking to them again tomorrow
Good questions I’m talking to mgr tomorrow thx! It sounds like they’re just going by the metal in the oil in the diff. I know they didn’t take it apart. They first said it was a loose retainer on the wheel lock on the hub. I know they took that apart, but said they didn’t find anything then went to the differential.
If there is metal in the differential, it is going to need a lot more than a ring and pinion. It needs most everything in the differential replaced. I would think that if this is warranty, they would just replace the whole axle assembly. If they do, please get me the part number of the axle assembly off of your paperwork.
Tremors have a limited slip clutch pack. The dealer might be mistaking clutch material for metal in the oil. Also if the squealing is coming from the hub their no way that it would make to the diff as they don't share oil. One last thing it should be safe to in 2WD provided the hub problem doesn't prevent it. If it were me I would find another more competent dealer as it sounds like a bad diagnosis.
Fine shavings in the oil is fine. Chunks of bearing or chips off the ring and pinion are more of a problem. Its highly, highly unlikely to be a diff problem unless you spend considerable time in 4wd. The driveshaft isnt spinning unless its in 4hi or low
They said it was a lot of metal. Only 12,000 miles and very few times probably 20 I ever used it in four-wheel-drive and not for long period it still doesn’t make sense to me that it would make a squeal out of the front left wheel if it’s in the differential.
Somehow managed to pop the rear diff in my 22. Took about 5 weeks to get the parts. Good times.
Then you need a whole new axle assembly. I do not think that I would want the tech at the local Ford dealer doing a complete differential rebuild. It is speciality job. I would think this is what they would do because I would think it would cost Ford lees than all of the parts plus the dealer tech labor.
Something doesn't add up here.
OP took it in for a squeal. No grinding, no clunking, no vibration, no indication that the 4wd doesn't function and the dealer says its junk??
I don't doubt the OP's symptom but I highly doubt the dealers diagnosis....
Id bet its pretty spot on for a pinion bearing to tight.
