Thanks! I have all that info...I was looking for input from folks that have pulled their bumper...Local Linex quoted me $350...which seems like steal if you have priced paint and clear lately.
Is putting the bumper back on a two person job? I see that you have to hold the nut plates while threading in the bolts before you can torque them down, and it looks like the bumper will want to “fall” off if someone else isn’t holding it on
Was planning on using some floor jacks....Getting a bucket or some other way to help hold the bumper in place can work. It's not overly heavy but a bit tipsy trying to hang it correctly. Maybe a portable work stand that's height adjustable....something like that helps out a ton.
I can't recall what I used or how but I've done it before plenty of times. Sure extra personnel is much easier, but you can do this solo on an OEM bumper.
Once you have the hardware started the adjustment to get it sitting perfect can happen later.
I installed the Warn winch, taking the front bumper on and off wasn’t too bad. I was able to do it by myself with some temporary supports as others mentioned. Once you get a couple bolts in to secure the bumper, you can align it and tighten the bolts to set it in place. Take your time with the plastic trim pieces. Good luck!
That’s what I was thinking as it relates to those nut plates. I was chatting with @trmrzla and he had a great idea when he did his, he used some grease to hold the nut plates in place.I leave the side brackets on the truck, and remove the outer most bolts. I then support the bumper (which will want to fall forward) when removing by using blocks or a floor jack with pads. The air dam is what will also cause it to want to flip forward on you.
I also did mine on my lawn to keep it safer when / there was ground contact. That does not matter if you’re going to paint it.
Removing the front plastic is easy to pull off, but behind them there are two brackets (2 on the left and two one the right -4 bolts in total) that will be the business side of the support structure. Be sure you remove ALL electrical connections prior to those coming out.
For me, DRL, Winch and the block heater did it.
Then you’re free. Reattaching is a bastard with the two threaded back plates for the front bolts (the ones by the tow hooks). I didn’t have much room to play with and they need to be lined up while you hold the bumper. I had my son help me - otherwise I would have not done it well. Once you’re attached you can raise and level as you snug.
