Ford Brake Bulletin
Sounds like you mite have shitty Machanic working on it not bleeding the brakes right or bad proportioning valve
Thats absolutely possible. I get the shitty mechanics while all the good ones are working on anything that says Shelby, mustang or roush.
So weird, I've not noticed anything out of the ordinary with the brakes and I recall having some times where I've had to apply some heavy pressure to stop suddenly.
IMHO, these brakes don't suck for a truck. I had a 2006 Chevy 1500 with drum rears and those brakes sucked...they were scary as hell for me at least when driving in traffic. I've also had amazing brakes with a BMW 135i (6 piston fronts and 4 rears). The F250 Tremor brakes are as they say "capable," at least the lighter more nimble 7.3 is.
I just purchased a brand new 2020 Tremor last Tuesday and about 30 miles from the dealership came upon a bad wreck on the highway I was on, applied the brakes (it was drizzling/wet and about 36 degrees outside), and felt the truck want to 'rotate' a bit as I got on the brakes from 65-70mph. I thought it was weird, but chalked it up to some oil or something on the ground, or the new tires not even yet getting worn in. Later on, as I continued the rest of my 2.5 hour drive home, I noticed it again coming into a few smaller towns, but it wasn't so bad. I wasn't getting on the brakes very hard since the truck was brand new. Fast forward to now having 220-250 miles on the truck, and it's definitely quite noticeable. I actually did an intentional hard braking last night after exiting the highway and it pulled hard enough to pull me into the next lane over. The LF rotor still looks almost brand new/unused with the cross-hatching still visible on the entire swept area of the rotor. The RF wheel has a lot more brake dust on it, and already has a 'high contact area' wearing into the rotor where the cross-hatching is completely gone. I don't normally use the brakes very hard in everyday driving, as the 7.3L has plenty of engine braking for the truck and I don't have any big hills around me.
The truck tracks just fine/straight otherwise, except under braking. Going to one of my local dealerships tomorrow for them to look at it, and will have them reference this bulletin. Much appreciated on the post above with that info on it!
Exactly what mine was doing.
they replaced calipers a few other components and it still did it.
got to around 750 km and it just stopped.
I truly think it was the Duratracs but cant say for sure....
My truck did it from day 1. I got the calipers replaced a couple weeks ago and they actually pulled the opposite direction from before. After driving it some more the pull went away mostly (somehow) It isn't the duratracs since I've had the issue with my 35x12.50 ridhe grapps. too. Its such a slight pull at extreme braking that ill just let it be.
same! If there is still a pull it’s insignificant enough that I’m not worried about doing anything else
So I realized above I posted how I felt like the brakes were plenty good, although due to a recent event I'm not so sure.
I understand that we drive heavy as hell trucks, but man when I had to do an emergency brake at 60 due to traffic backing up and stopping, I had an adrenaline rush. That freaked me out. I can't remember the last time I'd felt like whatever I was doing wasn't going to cut it. I wonder if there's something that can be done to upgrade the braking power or performance from the stock calipers.
Ideas: Less unsprung weight wheels/tires (difficult considering these trucks aren't street/track cars)
Upgraded pad composition, more friction on the rotor
Upgraded rotor size and pad size/surface size
different brake fluid
Stainless steel braided brake lines? (although this may be just for feel)
I don't know, I just feel like with this truck I have be much more defensive with how I drive and take extra care than with nearly any car I've owned before, except a hatchback with undersized brakes.
This is the last thing I'd want to do but also the first thing I'd love to do: Wilwood BBK
Has anyone found a Braided Stainless Steel Brake line kit for the front and rear that will work on our trucks
Holy S*@(#$. ~$5k for front and rear. It better do more than stop the truck if you know what I mean....
Snake pit has it on his bad ass rig. He explained it helped a lot. My truck is being built end of Nov but i picked up this set up. Power Stop kit for 2019 fits 2020 with stock wheels. 640$ with tax and shipping. I didnt get it at Amazon. He gave me a link and this wasnt the part # but was the same price. I'm still feeling ill so my mind is a bit off. Took a lot just to text this. Hit up Clint aka The Snake Pit. Ask himto show you a pick of his Beast. Really sick. If anyone is in Ohio he has a shop and does this for a living Modding up rigs.
Donald huh? That sounds way too professional of a name for a dude like you! I’ll stick to Don or Donnie if that’s ok with you. ??????
I know, I know, we've already been over this. I'm not for the drilled rotors but I'll bet those pads make a huge difference so perhaps that's the cheapest thing to do right off the bat.
Aren’t the drilled holes to keep the Rotor cooler and prevent warping.
I believe that is a misconception. The vanes do more than the holes do, and beyond that force air cooling through ducts provides more cooling effect. For the most part, those holes are for looks, at least for our application. They can cause more cracking of the rotors as well. I prefer plain slotted to simply clean the surface, but even those can provide less friction surface due to material being absent for the pads to rub on. Brakes are a very interesting subject, lots of information and misinformation.
