Finding a power leak
Beast2021
Tremor Buff
Founding Member 📜
NC
2021 F250 Tremor 6.7
Ok, non ford problem. Old old SUV two vehicles pre Tremor. 2005 Yukon XL Denali. Thing over time has clearly had some degree of a phantom power leak, but now its bad. I've put a few alternators in it, and the Battery turn over has been high.
Sat for a LONG period of time (insert joke about living in the country and having a non working vehicle here) - and the second shop I took it to ultimately found squirrels ate wiring harness. Painful, but my fault - fixed, new wiring, new alternator, new battery, running well. Brought it home, sat 24h, went out and dead dead. Jumped, put the battery on charger, dead 24h later.
Spent some time Monday - disconnected the negative battery terminal - put the multimeter in line between battery and negative - and got at least 1.1amp leak basically till the battery dies. Tried starting with the fuse block under the hood pulling one at a time, no change. I didn't make it through whole block before it died again, then repeated, charge, run, pull - and went through all the fuses inside the driver door. No obvious source. I was pulling one then replacing - so it is POSSIBLE that I missed one but I was pretty diligent going up and down one at a time.
Going to repeat process again pulling and NOT replacing - but lets say I pull ALL the fuses and its STILL pulling current - what then?
At the point the value of the vehicle isn't worth much more in shop time - so if I can hunt this down I'd like to. I would have assumed that EVERYTHING was fused. Anything that I should look out for that's not?
Thanks all!
Thanks all!
I believe there are some things not fused or use fuseable links in that vintage of GM vehicle. Starter would be the first one I would look at that isn’t fused.
I feel for you. Pull all of the fuses and relays. Start checking just like you have been. There is a possibility that when the new harness was installed, a positive wire was connected to a ground.
You are on the right track but not everything will be fused. Next step is to start disconnecting connectors to everything hat has one. Could be a short to ground in a wire (likely die to known pest issue) or a short in a failed device (would likely throw a code or act funny) or something pre-fuse or without fuse. If you pull the positive lead and measure resistance from it to ground what do you get?
Also make sure there is not a second fuse box in a kick panel. I have seen where something dumb like a light in the glove box, visor, center console, trunk stay on.
Great input all. Will report back tomorrow.
One more thing many overlook, even though you have replaced the alternator, it doesn't eliminate it as the culprit. An alternator uses diodes to rectify the voltage to DC and the diodes can l leak. When I've run into this in the past, pulled the alternator (bought rebuilt to replace a defective alternator) the store tested it, had ~100 amps output, but would still drain the battery over time. Finally got a new alternator and even it had some reverse leakage, but in the milliamp's region. I believe all heavy-duty diodes can be subject to leakage but not enough to cause issues. In theory, a silicon diode should have 0 amps leakage. But in troubleshooting heavy duty power supplies in a past life, many of the diodes leaked, just not enough to be a problem.
Some computers draw a miniscule amount of current at all times and this could also be a source for the issue. It's normal for the computer in that vintage of automobile to draw a small amount of current, but only a small amount. (Milliamps, not amps)
Try to pull the wire off the alternator to see if it eliminates or reduces the current draw.
