Factory Winch Remote Harness issue
Bitsniffer
Tremoraholic
Founding Member ๐Ÿ“œ
Amarillo, Tx
2022 F-350 6.7L Lariat Tremor, Iconic Silver
2000 Jeep Wrangler
Winch was not working so after digging through previous posts, I went looking on my connections. Front connection, at the fairlead, was corroded through and the red wire was totally snapped off. Tried looking to find parts with no joy based upon the angled connection where it connects on the fairlead. Sent word to Warn asking if they had a cable replacement, $361 and includes the fairlead. Anyone know the female pin connection type? The red wire is bare right at where the connection should be and in looking at the 7 pin keyed connection (5 pins used) the location is clean. No pin connection remaining. I know there are two empty holes in this connection.
Trying to find the female "cup" that accepts the pin from the wired/wireless remote.
Thanks in advance.
After reading these forums, wish I would have just purchased a HF Badlands and saved a bunch of money.
Edit: Essentially, I need the opposite of this!
I saw some on his write-up. I think it was the other end of the same remote harness.
  • Staff ๐Ÿ›ก๏ธ
  • #4
What a pain in the butt. Mine was the other end, but you can just buy the fairlead to the connector for cheaper. I believe they quoted me 150ish?
Warn quoted me $361 for the fairlead and cable. Where did you get the quote? P/N?
Every end I can find is round and not keyed like our remotes.
Itโ€™s just one broken pin at this point. If I could find the female pin, I could probably get it working.
  • Staff ๐Ÿ›ก๏ธ
  • #8
I think I was confusing it. I had only needed half of the harness (like you do) but I needed the other half. The entirety was over $600 bucks as I re-read my old posts.
I like the idea of re-pinning it. It should not be impossible. You can buy pins on amazon.
Just need to know which ones. I have the skills.
