I had some work done on the Tremor and they had to remove the bed. Now the bed bolts are not bed lined and I want to fix it. I also have some damage from use in the bed liner that could use some repair too. The truck has the factory spray in bed liner. It is not soft or sticky. Most things still slide on it and it does its job. I doubt anything would be a perfect match because it has faded unevenly over the years and any repair material is going to fade too.
I looked around and there are lots of products for spray bed liner repair and also the roll on options. I could just pick one and go but thought I would investigate what others have done.
What have you used to repair your bed liner? Why did you pick it? Would you recommend it?
