F350 Platinum Tremor - Antimatter Blue
Kropatch
Valley Center, CA
Navy
It's been years in the making - but finally got my tremor ordered!!!
Been stalking the site for a long time - appreciate all the help it has been.
Order went smooth - couple of notes - these areas were causing delays (or Ford not accepting the order):
- Adaptive Steering (removed)
- Winch (removed - but will buy separately and install later)
- Hood deflector (not sure why this was a problem - but easy to add later).
- Vinyl Flooring (haven't seen anything on this - but apparently they aren't allowing the vinyl flooring on higher trim levels??? - will just order good floor mats)
Dealership is expecting the order to be 3-4 months - now that these are removed.
Will keep the updates going as I get them.
I just removed the adaptive steering from my Platinum order as well. the other thing I was advised to remove was the factory bedliner, he wasn’t positive that it was another cause for delay but it’s easy enough to get that done locally anyway.
I left the spray in bed liner and tonneau cover - the dealership was worried about those at first but checked everything and those didn't seem to impact the order. We'll see what happens!
good luck
