- OP 🔹
- #41
Yeah, that 3.73 is my preferred rear end too. I bet it would be perfect for both engines
Minor detailsYes! But then, you would have to change your username to TxNonTremor...![]()
Gas mileage?? Really? Buy a toyota prias then. LolI don’t know if the 7.3 has enough ass to drop to the 3.55 for fuel mileage. The 6.7 obviously does. That is why I am asking. Big difference between an old 03 5.3 and the 7.3. Asking questions is how we learn things. I don’t want to just assume the 3.55 won’t work when all the documentation says it will. That is why I’m asking for real world experience .
Re-read my comment “Not that MPG is a significant consideration, but it should be reasonable.” One would or should not expect to stop at a gas station every 40-miles.Gas mileage?? Really? Buy a toyota prias then. Lol
Asking about gas mileage is perfectly reasonable for two reasons:Gas mileage?? Really? Buy a toyota prias then. Lol
I get 12-14mpg mixed driving with my f250 7.3 gasserAnyone purchased the F250 Tremor with the 3.55 rear end? How is fuel mileage and low end torque? I will only be pulling bumper stuff under 10K so it should be fine, right?
I hate you guys as before I joined this site I knew exactly what I wanted….F350 KR 6.7L carpet. What I’ve learned on here about the trucks being identical made me already drop to the 250 and save 1,100 off a-plan, and since I’ll be on the farm, I dropped the carpet for vinyl. Now since I read about how happy you guys are with the 7.3 and the 8k savings, I’m considering that move now. I love diesels, don’t get me wrong, but I’ll never tow the weight that actually requires 1050 pounds of torque. I can use that 8k to get the winch, Adaptive steering and adaptive cruise, and a few other o-toons I didn’t get to keep the price down.
Like I said, I hate you guys for making this once easy decision more challenging….lol. So thank you and I am grateful for all your shared knowledge. You’re the best…lol
edit: You can only get the 7.3 with the 3.55 rear end in the F250. I tried adding it with the F350 and it makes you add the 6.7L
p.s. I don’t hate you all….I am being facicious
LolRe-read my comment “Not that MPG is a significant consideration, but it should be reasonable.” One would or should not expect to stop at a gas station every 40-miles.
Even towing a 9500 lb TT, I was getting more then 300 miles per tank!Re-read my comment “Not that MPG is a significant consideration, but it should be reasonable.” One would or should not expect to stop at a gas station every 40-miles.
No higher than 3:73. By higher I mean ratio, not numerically. You have 2-3 overdrive gears in that Trans and you're running 35" tires you don't need to run 3:55 gears in this truck.Anyone purchased the F250 Tremor with the 3.55 rear end? How is fuel mileage and low end torque? I will only be pulling bumper stuff under 10K so it should be fine, right?
You can only get 3:55 with 7.3 F250??Anyone purchased the F250 Tremor with the 3.55 rear end? How is fuel mileage and low end torque? I will only be pulling bumper stuff under 10K so it should be fine, right?
No, you can only get the 3.55 with the 6.7L Tremor. (F250 or F350). Non-Tremors have other options available.You can only get 3:55 with 7.3 F250??
I was repeating someone else's question, I know they go into the 4sNo, you can only get the 3.55 with the 6.7L Tremor. (F250 or F350). Non-Tremors have other options available.
then buy the diesel ... it gets 20 mpg without tryingGas mileage?? Really? Buy a toyota prias then. Lol
Why buy a tremor if you dont want the gears? They only come with 4:30s for a reason, makes no sense just buy a non tremor.Just stumbled across this and having to get the 7.3L with 355 gears, makes me want to look deeper into the 3.55's and if they are worth getting with the Tremor package
Unless something has changed in 2022 ordering, when you change the axle ratio on a 7.3L from the 4:30 to anything else, it pops a message saying it will remove the Tremor package.Do not tow, will be using it for a long ass camping (tent) trip across Canada to Alaska, tons and tons of highway driving, then lots of really bad roads/trails and such in Alaska & the added mpg might be important across remote Canada and Alaska and can not justify the additional cost of the diesel. Wish they came with a bigger gas tank, but that is not a option or even a aftermarket item.
Using 4low and the gears with the transmission locked out will provide more than enough grunt when we need it, even 4 wheeling in Moab and the San Juan's using the 4 low system when off road Vs depending on the 4.30 gears to save the day
Do not plan on ever putting on 37's but just going with a Carli backcountry kit for off and on road ride improvements
