F250 with 7.3L and 3.55 gears
Your opinion, and it is my money, I can focus on what I want to focus on. I am asking a simple question to a specific target. Anyone who has a f250 of any kind with a 7.3 and 3.55. But all I am getting is people like you who have zero experience with that combo, spouting your opinions only about why I am F'd up for even asking the question. So why don't all of you know it alls with zero experience with this combo and just spouting your baseless opinions, move along because you are just trolling and it isn't helpful. Those that have family that, or those who work for, Ford or a dealer, who say you can't get this combo, I am fine with their opinions. But your opinion is asinine and argumentative, making you come across as just a pr!ck. So thank you for your sage advice, but I don't need it.
I'll contact my dealer later and ask if this is a website issue or if Ford actually offers the combo.
Not that I need to, but I will respond directly to your post I am not "concerned" about fuel mileage by and in itself, but since it will be my daily driver, it is one of many considerations. Top being the towing ability for that combo with a 4 to 5 K bass boat, and 2 with an occasional 10K to 13K conventional trailer. If the towing sucks, then that negates the fuel mileage condideration.
I am sure when you picked your truck, you had an idea of what items were important to you. You saying what is important to me, means that I've chosen the wrong truck, is just stupid. Unless you are going to pay for my truck, keep your opinions about what truck is not right for me to yourself....THANKS!!!!
I will add to the actual question. When looking for a Tremor all that was available to drive was non Tremor 3.55 7.3Ls what I noticed from the test drive of those vs finally driving a Tremor was a little softer ride and not as snappy on take off. The ride had to do with a different spring pack used vs the regular and Tremor but was not a huge difference in my opinion but take off seemed more noticeable. I have not tried towing with the 3.55s so can’t comment on that. There is another form for all Superduties that may get you better response on the 3.55s since there seems to be a lot of people on there with the regular 7.3L 3.55 combo if Ford did add the option for 22.
Another thing to consider is the 4.30s were the only way to get the larger Dana M275 axle in a 7.3L. All the 7.3L 3.55 trucks got the smaller Sterling axle regardless of F250 or F350. It may or may not make a difference for you but something to consider if 3.55s are being allowed in 22.
I do know that the builder had the 3.55 7.3L Tremor combo available in 2020 when ordering mine, but when building out different trucks at the dealer in the ordering system would not allow a Tremor 7.3 with anything but the 4.30s.
I have a 2020 7.3 with 3.55s and pull a 12,000lbs camper when fully loaded. No complaints towing, 8-10 MPG towing, and great MPG when I'm not towing (for a gas 3/4 ton). I also use ethanol free 89 gas from Wawa
Just curious what "great" is? Not trying to start a fight or anything, just wondering what you're getting unloaded.
I tow locally up and over a mountain on a regular basis.
The 7.3 chugs up hill. And what I mean is, it’s got plenty of pulling power, but it literally chugs fuel.
If I could go back in time and order it with 3.55 gears I might, but I would probably just get the the diesel instead at that point.
The 7.3 is just too much of a pig.
I very much appreciate the simplicity of the drivetrain, and the price to power ratio, but it just does not make sense for regular towing from a fuel range perspective.
So I appreciate what you’re hoping to accomplish here.
No problem, like I said great for a 3/4 ton lol. The highest I've gotten on the screen is 21mpg...which when refueling and doing actual math it was 18. My usual average is around 15-16. I'm also in Florida so mostly flat roads.
Damn! That's still pretty good. I'd shit myself if I saw that on my screen in a super duty.
Oh yeah, I knew there was no way it was really that high so I made a point to calculate it myself when I refueled. My usual drive is 65mph backroads through orange grove country. I will say ethanol free 89 gas from Wawa is definitely worth it. Normally it is around the same price as 93 premium and seems to add power and MPG. Hopefully it keeps the engine cleaner as well which is the main reason I use it.
Tremor 7.3 is only 4.3.
I seriously doubt Ford developed a LSD in 3.55 for the front axle. This was the likely barrier to adding the lower RAR.
The top 3 gears in the 10 speed are OD gears, and it plays well with the 7.3 with the 4.3. With the 3.55, you'll likely never use tenth gear towing anything heavy or over hills.
Yes, range sucks. Yes, mpg suffers. It's a big block in a 3/4 ton with a lift and off road tires.
If you truly want to improve fuel economy, replace the front valence with a standard 4x4 SuperDuty one, and replace your tires with ones with less rolling resistance (i.e. street oriented tires). That will likely buy you 1-2 mpg. The rest is driver behavior.
two months ago I traded two trucks for more than I paid, because one was having an issue, (the dealer knew about the problem), and bought the only Super Duty on the lot. A 21 F-250 CCSB 4x4 Lariat with 3.55 and 7.3. This truck has the value package and 5th wheel prep. It has a payload sticker sporting #2936, which is pretty good considering it's a 250. Great truck so far, and only about 1700 miles. Haven't pushed it beyond daily driving to work. The truck was kind of a dog at first, and wasn't pushed in the first 1000, but after that amount of miles, it has woken up. It's got plenty of power when you need it. Of course, I'm running with an empty bed, but it runs different now than it did new off the lot.
It is for sale at point of sale when my F-350 Tremor comes, or will be traded at that time if not pre-sold. Proposed build date 8/23. The whole time I've had it it has had 12.6 MPG 50/50 highway and local. Probably not the info you're looking for, but maybe a little.
This does help, thank you. I was hoping for better mileage out of the 3.55. If it isn't much better, then the 7.30 seems the best way to go
Like I said earlier, mileage is only a fraction of my decision. Seems the documentation says 4.30 only, but the website says otherwise. So I'm waiting to hear from the dealer. Thank you.
I'll wait for the dealer since there seems to be this disconnect.
Thank you everyone
I don’t know if the 7.3 has enough ass to drop to the 3.55 for fuel mileage. The 6.7 obviously does. That is why I am asking. Big difference between an old 03 5.3 and the 7.3. Asking questions is how we learn things. I don’t want to just assume the 3.55 won’t work when all the documentation says it will. That is why I’m asking for real world experience .
Go on a non tremor forum and ask?
There's a video on utube that a fella shows you how recalibrate your truck to show the actual MPG you calculate
I have not taken it on the highway any more than a few miles back and forth for work.
I figure I'd get closer to 15 - 16 on a highway run, as that's what others seem to get, and that's what my 20 6.2 F-350 got with 3.73
Unless they made a change for 2022, when you add the 7.3L and Tremor packages, it defaults to the 4.30. If you try to change it back to the 3.73, it removes the Tremor package. (I tried this many times in early 2021) Also, if you add the 6.7L and the Tremor package, it defaults to the 3.55 without allowing you to change. If your special order is not doing that, then there is a glitch in the 2022 ordering process. FYI: Your screenshot does not appear to have the Tremor package.
I went around and around with my dealer on this point when I ordered my 2021 6.7L and he confirmed you could only order the Tremor with the corresponding "matching" axle ratios. For this reason, you will not find anyone on here who owns a Tremor 7.3L with the 3.55 or a Tremor 6.7L with the 4.30. (I wanted the diesel with the 3.73...)
In the end, I am very happy with 6.7L and 3.55, as it gets decent gas mileage when empty and tows like freight train when loaded. :cool:
It must be a glitch unless my dealer says different. Haven't heard back yet. I scrolled down to show the 3.55 and tremor
Exactly what I was going to say. If I went non tremor this would be the combo I would consider.
Yes! But then, you would have to change your username to TxNonTremor... ;)
