F-250 Trailer Tow Package Question
If it were my build, and this is just my two cents, i would go with the F250 KR and take the winch off.
F250 because of the reasons above. I don't believe the resale value is going to be significant enough for the difference in payloads. Plus the F250 already has the F350 rear springs and axles.
I would take the winch off because it's 2,400$ (give or take) at a different dealership and it takes about 2 hours to install. Not worth the 600$ price difference to have it preinstalled. I made this mistake on mine.
Otherwise, order it.
note this for your build. There's a lot of chatter about the 5th prep adding delivery time to the build. I can't site Ford specific sources but it seems to be that case. That and the adaptive cruise control.
I think I'm going to take gooseneck off. I'm honestly never going to use it, and I feel like the truck would sell fine if I needed it to. Here's my updated build. I added the LED lights. Think I'm going to keep the winch even if I bite a bit on it.
Let's take a second to back up on this post here. The trailer is GVWR of 8,800lb. Quite frankly that's F150 territory even without the F150's max tow package. The F250 will WAYYYY more than handle this trailer, it's not even a debatable topic. The F350 is so much overkill for this size trailer it would be comical. The bumper pull rating on the 22 Tremor package (which has reduced towing capacities) is 15K lb. You'll be fine in a F250 zero problems.
What you should be asking yourself if whether or not you want the cameras. I have the UTT, I pull a 10K enclosed trailer and/or a flat bed for my tractors 10ish (😉) K lb. each. Other than using the cameras to hook up the trailer I don't find them hugely useful.
The trailer camera can be added to trucks without the UTT system so if you want to add that trailer mounted camera just buy the kit and add it to the truck. I have done this and I do find this useful. My enclosed trailer is 35' tip to tail and having eyes at the back is nice in tight spaces.
All the above said, I find I use the UTT (more specifically the 360 cameras) when I'm parking the truck in stalls. It's nice to see I'm between the lines and not about to hit the car across from me.
Summary, go F250 with the UTT system. You won't regret it. Once you're comfortable with the truck I think you'll find yourself using the mirrors and instinct more than you do the cameras.
ps. Check your state's registration laws. In some states the F350 is taxes/registered/insured at higher rates given it has higher capacities. Another bump to the F250 if you're in one of these states (I don't know Idaho's laws specifically).
He may be able to tow his trailer legally with an F-150, but only with specific and careful conditions and considerations. The maximum trailer weight in the towing guide is not very useful. The more important number is payload and the rear axle weight ratings on the truck. My trailer has a GVWR of around 7K but has quite a heavy tongue weight. When combined with some camping cargo in the bed, my F-150 with the max tow option was still 400 lbs over my rear axle weight rating. Unless you’re pulling a small cargo trail (think uhaul), my experience says that many trailers that have a GVWR around 7k will cause you to go over your payload limit long before you reach the max trailer weight limit. I think a super duty is a much better, safer, and possibly more legal option for towing the OPs trailer.
Exactly! For example my last F150 2.7L EcoBoost could pull the example 8800lb GVWR trailer but only had ~1350lbs of payload. Load up the family + the tongue weight and I would have been over, no question...
I forget most of you have families.... I'm single and basically tow my own toys around. For which the F150 would be fine with an 8,800# trailer.
My 60# dog and 100# of camping gear don't really tip the scale. :D
