Exhaust system Upgrade debate. HELP
The Ford Performance Exhaust has a great overall sound. This is the very first vehicle I've had since 1999 that had anything other than the factory exhaust as I am not a big fan of noise in the cab.
The recent install of the Whipple completely changed the sound profile, below is a basic summary of each. The Ford Performance Exhaust was put on at the Dealer before delivery, so I have no "stock" exhaust reference to compare to just the miles put on the truck before the Whipple install.
~1600 miles driven with it Before Whipple Install
- Great Tone, throaty but not too loud
- You hear it at initial start up, but quiets to a slow rumble you are can barely hear in the cab at idle
- RPM Range ~1000 - 1600 slight noise in cab, but not much more than road noise
- RPM Range ~2200 - 3400 almost silent
- ~3500+ RPM's you really start to hear it
- ~1700 - 2100 RPM's you would get a slight drone when going over overpasses or situations that required additional throttle without a downshift in that RPM band. Radio level (22 Model) 10 or more, you didn't really hear it over the radio.
Summary - Although no loud drone, speeds between ~65MPH and 72MPH you would hear the exhaust rumble with varying engine loads. Keep in mind I'm picky and like the cab quiet. If you had the radio going on anything past 9 or 10, you couldn't really hear it.
~300 miles drive with it After Whipple Install
- Great Tone, a little deeper but sounds really good
- You hear it at initial start up, but quiets to a slow rumble you can barely hear in the cab at idle
- Virtually No drone through the RPM band. You still have a slight rumble in the 1700-2100 RPM band, but seems much quieter than the stock engine configuration. The Whipple whistle competes with it.
- It has great sound when you accelerate hard, but not obnoxiously loud. Again the Whipple configuration seems to mute the overall sound. Not sure if its because the Whipple whistle drowns some of it out, but it definitely sounds quieter even in the 4000 - 5000 RPM range after the install.
Turing the radio volume at or above 7 or 8, the exhaust sound is not noticeable under normal cruising speeds.
Seems like the more fuel and air you push through it, the more resonated it gets. It's almost as if it is tuned for a little more airflow, so if you were towing with a stock engine setup, my assumption would be your RPM Band and additional air/fuel would get you out of any drone spot. Also, if you run 75mph+ during your trips it has almost no exhaust sound.
Drone and sound are very subjective and sensitivity varies with each individual, hopefully the radio volume reference and descriptions provide a reference view point. To be honest, not sure the noise, except under hard acceleration, is much more than the diesel sound from my 2017 6.7L, just different noises. I kept my stock 7.3L exhaust in case the FP Exhaust too loud but at this point I think I'm going to keep the FP exhaust on and would probably purchase it again. The fit, finish and look is top notch.
Awesome review, Man! Much appreciated. Theres still too many damn choices on the market now a days. But I will definitely be pricing out the FP first and foremost.
One thing to add, that under all situations you can easily have a conversation with people in the cab so the amount of sound is not overpowering.
Thats the main reason i dont really want to change it from factory, I dont want to hate it afterwards.
I have the SW long tubes and Legend catback. I love it, deep and loud when you want it, no drone and quiet on the freeway. It was done at same time as the pro charger was put on, I did not do it myself but looking at it, the headers would be a tricky install, but they all are on modern vehicles.
The cold start sounds like a nascar but it should be with 638 hp to wheels. But it quiets down quick, the neighbors love it. I go to work at 430 am.
I do NOT recommend the Borla. It has completely ruined my MPG as it sounds so F’n good I have my foot in the floor every time I get a chance. I was between Borla, SW and the Ford Performance. I went with Borla based on past experience, reputation and countless YouTube/Audio samples.
No drone, quiet in the cab, I don’t blush when I start up early morning within a neighborhood but good lord it lights up when you tell her to. Now I’ve never heard the SW in person but I do like the dual outlets which provides a better aesthetic IMO. Good luck with your search but fortunately you have a few options that should do you well.
@Trent-20Tremor7 if you were close I would give you my MBRP for cheap to try. I took it off my ‘21 but haven’t put it on my ‘22. I’m probably going to leave it off.
Ah damn, price the shipping to salem oh, And PM a price, see if we can work a deal.
That sounds like a sweet setup. I've been looking at SW headers and high flow cats and thinking a while down the road maybe procharger. Do you have any issues with engine lights or error codes? How's it holding up as far a reliability goes? I currently have SW redline catback and love that but want a little more
Oh ya I get an exhaust code sometimes, it is what it is. No way to keep it off I do not think. It runs and drives great, truck only has 6k on it now. 5k w all the work done.
Anyone have the AFE Apollo GT exhaust system?
I ran this on my 21 7.3 and it sounded really good. Deep throaty tone, not loud.
I purchased the AFe exhaust but having trouble separating the pipe between the muffler and the can. Tried a little heat with portable torch but so far no go.
