There might be few cases of that depending how the vehicle was operated and maintained, worst case scenario including bad fuel.It will catch up to you, trust me.
It doesn't take much to start building up carbon, by the time you've reached 50K, your intake will look like clogged arteries. Your engine will be starving for air most of its life.
In reality things are not that bad. Especially not at 50k.
I've replaced heads and did EGR delete on my 2006 6.0 at 250k miles. Had it since new. EGR valve needed occasional cleaning because it was small and in bad spot. Inside of heads and on back of the valves there was no carbon build up and that engine always had oil in the intake (stock pcv) + exhaust gases flowing trough.
Opened stock Turbo as well and it was clean and functional because Ford added command whenever it idles to fully open and close VGT veins.
The only thing apart from EGR valve that was clogged was intake air temperature sensor. Didn't even know it was there and in 250k was completely covered but still reading the temperature.
That's all on the old engine from which they have learned few things. 6.7 has much bigger air flow openings, let alone EGR cooler and valve in different place.
I've seen carbon build up on intake ports and back of the valves on direct injection turbo gasoline engines. It's more common because of the different operating temperatures and fuel chemistry. Those can build up and affect idling speeds.
Not so much in diesels.
These days everything is exaggerated because so many companies are trying to sell aftermarket products.
Have to add I will delete this one as well but she'll be good for at least 100k while under warranty with occasional sensor needed to be replaced.
