Engine runs hard and shifts late
Chasenabby
Northern Michigan
2021 F350 Lariat Tremor
2021 F350 diesel 58,000 miles
Whenever I hook up to a trailer no matter the size or weight the truck acts likes it hooked to a Freighter. Engine is loud and it seems like it struggling. The shift points are much higher than usual.
Once I unhook the trailer it still does it.
I have to put it in manual and shift it through the gears. then put it back to normal and it’s fine.
I’ve had it to the dealer and of course it didn’t do it when they test drove it.
It’s is intermittent but is no like 80% of the time messed up.
Any ideas?
Weird? Like really weird I think you have a Trailer system fault would be my guess wigging out the system (assuming you’re using the 7pin) since it’s immediate when you hook a trailer.
Chase, are you using/have you used the Tow/Haul shift map? Cuz it sounds like your truck is defaulting (as in a "glitch") to that map when you hook up a trailer.
Not enough folks know or use the Manual shift feature like you do, so you're ahead of the curve.
i use the tow/haul mode when hauling my pontoon boat but not with my landscape trailer or when pulling my 14ft boat.
The “glitch” happens with all of the trailers. It will also do it randomly.
