Engine failure
Grumpysteve400
Tremor Fan
Oregon
2020 f350 xlt tremor 7.3 godzilla agate black
Anyone engine fail between 30 to 40 k ?
7.3? Can you provide any additional details?
Not mine. Just had seen on you tube some fails. Wondered how many or how common.. lifters and cams de laminating.
I’m assuming this is the 7.3 only.
there has been a few cases of lifter delimitation in a few early chassis cab, rv and bus platforms. I have a friend that’s a lead tech at a ford dealer, he doesn’t turn wrenches anymore but supervises and sorts out problems other mechanics can’t sort out. I asked him about this, he said it is a very small amount of engines effected. He told me that ford got a bad batch of lifters early on. He has seen 2 7.3 engines effected, one in a chassis cab and another in a bus.
  • Useful
Reactions: ccw
Spot on @Explorerinil
I also have it on good authority that it is extremely low numbers of engines in the field. Furthermore, it was a supplier manufacturing issue, so there is nothing inherently wrong with the component design or system.
Less than 2% are effected, far less than the industry standard failure rate. FYI the failure rate for other ford engines is higher than the 7.3.
It's less than that. The number I have seen in multiple spots is 1 in 500. That actually makes it .002%
2% failure would be a huge problem for Ford. That would be 2 in every 100.
Ok. Tks. For the info.
Well I got the 2 right! Lol maby he meant that or maby 2% total for all 7.3 produced?
