Door Sill Pulled Up
Cttullamore
Tremor Fan
DE
Anyone else have the door sill metal pull up? I’m imagining someone kicked the bottom or got under and pulled it. I climbed in the passenger side and managed to cut my leg pretty good. I tried pressing it back flat but still sticks out and relatively easy to catch on getting in. Wondering if anyone had any luck getting it to lay flat after pulling up before I just pull it all the way off and replace it with the tufskinz.
Just noticed mine was like that today. The car wash guys are the only thing I can think of.
Krap. That needs to come off.
Yea didn’t think it’d be sharp or anything but the gash on the side of my leg says otherwise. I like the look of the tuffskinz so don’t mind, just figured I’d check in case anyone has run into similar since I don’t know how difficult they’ll be to pull off entirely I’m
Happened shortly after delivery... I was snagging my shoe/heel on it - perhaps it wasn't flat when I first got it. 🤷‍♂️
The dealership replaced it under warranty. No problem since (yet)
This happened to me recently and I couldn’t get it to lay flat…. I ended up purchasing a new set from the putco website. When taking off the original one from the truck, I found that a strip of the cover on the sticky backside wasn’t peeled which caused it to be raised.
You could probably get it to sit flat with a rubber mallet
Glad I saw this response. Swung by dealer and said they'd replace it under warranty. Just waiting for part to get delivered. Hadn't even thought about that possibility...
I should stop in the dealer as well. I had one completely fall off and not sure what happened to it. I have two others that are starting to pull up.
Feels like something they just slapped on, last minute.
This thread has me questioning my decision to add these to a non BAP SD. I thought they would be a nice touch, so I bought a set, haven't installed them yet.
Mine have pulled up on driver front and passenger rear, haven’t had any luck fixing without removing. Was thinking of removing the rear passenger and trying to straighten in a press and reapply with new tape before buying a new set.
I wouldn't even consider buying these at the regular price of almost $130. The only reason I grabbed a set was Amazon had them for $65. Price went up to $71 after that but says only 1 set left.
Mine is coming off and catches my boot. I will be going to the dealership and having them replace it. Thanks for the info.
Was just told last week by my wife that my passenger one is lifting, anyone take it off and bend it back then re-double sided tape it?
Same here. Drivers side happened first but when I looked the front corner of the passenger side was not flat. They replaced both under warranty and no issues since.
