Door rattle solved with GM part (YouTube find)
Does anyone know the part number for the Door Latch Bolt. I stripped one and want to replace it. Google is not my friend on this one and many parts houses have not updated for 2021 and 2022 model years. I assume it has not changed but wanted to be sure. Thanks in advance.
Sent the new GM latches to get powder coated prior to installation. Looks a bit more OEM now.
Why do some doors rattle and others don't? Mine are all fine. Intuition tells me it's an adjustment issue. The second choice would be a variation in production specs but I find it hard to believe a pissant part like this would have such close tolerances. These aren't exactly piston rings, or are they?
If you look through pictures of trucks on here -- you'll find a wild variation in alignment of doors. Could be related to that.
Then there's also variance in usage -- if you drive on smooth roads all the time there's obviously going to be less wear than someone who lives down a rough, constantly washed out, dirt road.
Or maybe people who just open and close their doors a lot.
Generally speaking, from the looks of those that fail -- they will all fail. It's basically a plasti-dipped latch -- of course that plastic is going to fail. So the variation could also just be whether or not the user notices or cares.
Mine still rattles $)$(%^*%*%(!!!!! Fricking Ford should have known better!
Stopped about a week after I posted this! It worked at least on mine.
"So the variation could also just be whether or not the user notices or cares."
Trust me, I care. Nothing winds me up like rattles and squeaks.
I've had Mjölnir almost a year now and done a fair bit of wheelin'.
He's still purring like a Rolex, which is to say, silently.
Update after 100 miles of driving on broken roads - Highway 101 in the Bay Area (worse roads than Detroit, and I lived there).
Not worth the effort or the money. Door still jiggles. I can here it squeak against the door seals...still annoying.
The alignment of the latch is such that it's 1/4" higher than the OEM one, and it subsequently lifts the door up when it closes, preloading the hinges so it doesn't jiggle.
That simply makes it more difficult to open and close, with no benefits of a better seal.
My powdercoated latches are now for sale.
A 1/4"? That's huge! How can that not be bad for the hinges every time the door is closed? I hate it when my doors fall off!
Maybe there is a variation in the seals with the rattlers' being too thin?
If you think it is the door seals squeaking use some plumber's silicone grease meant for water valves (I used Danco). I used this on my '15 Super Duty, because the weatherstripping was squeaking. It solved the noise and does not wash off. Make sure you take the time to rub it into the seal. You will see what I'm talking about if you decide to do it. The other 2 Super Dutys I've owned have all developed at some point the passenger front door rattle from the latch/striker (Driver's door and back doors never a problem). The only way I've been able to fix it is wrapping some electrical tape around the striker. It's a temporary fix and has to be redone from time to time, but it worked for me.
Just ordered some, thanks!
This year is one of the worst I've seen in Wayne County. Heaving and potholes like no other and I've been driving here for ~30 years
I thought I was going to need to do this mod - but it ended up being the seat belt hitting/tapping the passenger b-pillar when there was no passenger. I flipped the belt (which was slightly twisted) and it went away. I think I am going to toss some small fuzzy-side Velcro adhesives on the b-pillar.
I just ordered some of this latex tubing to hopefully cure my wind noise and door rattle instead of messing with the door strikers. I will install the tubing inside the weatherstripping that is mounted on the cab side.
Agreed. I've ordered some myself from your link. I'll be interested to hear how this works.
I did this last year. No change with the rattle I was hearing. What I found was that the U-clips that the bolts under door handle thread into were rattling. Put a little Gorilla tape on the bare metal, no more rattles.
how or where are you guy's running the rubber tubing thru the weather stripping ?? i would love to try that for my wind noise.
Mentioned above in my post. On the weatherstripping mounted on the cab side. I'd do it today but it's raining.
i will look at it and see if i can figure it out. thanks
I was able to get one rear passenger door done today!
Fishing the tubing through is the hardest part of the job. I first put a piece of painter's tape with a pen mark on it to mark the center point of where the weatherstripping ends originally were.
After removing the weatherstripping from the cab, I used a 20 ft. Klein fiberglass fish tape with the rounded end cut off, and used silicone spray in several of the holes in the weatherstripping to get the job done. Keeping the weatherstripping as straight as possible really helps.
I bought the fish tape only for this job, so wasn't too concerned about cutting the end off. It was really just too bulky to fit through. Be mindful of not poking a hole through the weatherstripping when you fish it through. Putting a little ball of electrical tape on the end would probably reduce that chance.
I know what to expect now to do the remaining doors, hopefully more quickly. I may do my driver door tomorrow so at least the lefthand side of the truck is completed.
The door 'thump' sound when shutting it is quite satisfying now compared to before!
I ordered another pack of tubing because I'm unsure if 50 ft. is truly enough.
