Door rattle solved with GM part (YouTube find)
I ordered a set also.................from wholesalegmparts.com. Cheap enough swap-out to prevent an annoying rattle. Thanks Vermonster for the lead!
one of mine dropped in the pillar when removing, it took me an hour to fish it out. the strikers help with door rattle. My other issue is the damn doors popping and cracking when opening and closing the doors. I had the door detents replaced, still do it!!!
I swapped mine out this morning. Doors definitely sit tighter. Have pull closed with some authority. Worth it.
Same with mine. After a little use it "smooths" out some. I still got some rubbing noise from the rubber strip though. In order to fix that, I ordered new weatherstripping and prior to install, fished 3/8" OD surgical tube through the middle of it. So far, that has all but eliminated the noise. I ordered new, rather than used the one I had, due to the original having a crease and being flattened from use. The new one, is all fluffy and no crease so I figured it wouldn't flatten out as much and lose its contact pressure as much.
While I have no problem doing these things as fixes, it just pisses me off that we have to do them on a vehicle that is $40K plus. I wouldn't accept that noise on a $15K car. In the end, it is just craptastic fit-and-finish quality control.
Would the tubing help with any perceived wind noise too? I'm trying to decide if I need to add that to my sound proofing list for the audio upgrade.
It should. The surgical tubing is a little stiffer which keeps a bit better seal/pressure against the metal. Also, I started using a silicon-based lubricant (liquid) on the weatherstripping. I spray the silicon on a rag, liberally, then wipe the rubber down on all four doors about once a month or so.
This thread brought back memories. My dad had a 1991 Ford F150 XLT Lariat -- and the doors on that thing rattled horribly when you got on dirt roads. Which for us was pretty much all the time.
Don't have my truck yet, but I'm going to pre-emptively do this the day I get my truck home.
My drivers door just started rattling this week, almost 12k on clock, also have and heat shield rattle 3rd thru 8th gear...Already called my service dept to have both addressed at my next service...its still under warranty they can mess with it. I got better things to do with my time...like load development for hunting season. Aug 1st be here before you know it.
The only problem with this is that for the door/weatherstripping the dealers can be asshats. Most of the time, you will get a tech that will look at the problem on the ticket, maybe drive the pickup around, but in the end do nothing and put on the ticket "failed to reproduce." Then you will get a call to come pick your vehicle back up where upon your arrival the service writer will tell you that this is a heavier duty suspension and they are going to exhibit these things, it's normal. Unless there is a noticeable problem with the weatherstripping they won't bother replace that, and it is expensive at $180 a door.
For the heat shield rattle, that is hit or miss, but they actually crawl under there and do something.
Forgive my cynicism, I've been through this now on three F-250's and got tired of arguing with them. So, I just did what I could to fix it myself. You may get lucky and have a service department that actually fixes it.
Couple questions / comments.....
First any tips or tricks NOT to lose the inside piece in the door jam??
Second, I would agree with regard to fixing stuff on your own if you can!! This day and in age, service departments and their "mechanics" and even service managers have gone down hill. Sadly it seems no one cares or gives a $hiT. Whether its the work they are trying to provide or the lack of care for your expensive vehicle you are bringing in for work or service,.......no one seems to have pride in their work or workmanship. Mechanics are now "techs" that can't seem to diagnose anything and simply look the issue up in their system and the computer tells them what to do. When that doesn't work, most don't know what to do next.
For these reasons, if you can fix something yourself, and it won't cost much, then just do it yourself and save the headache or even further issues!!
So in other words, I'll be just doing the door latch upgrade myself!!
With that............."thanks again to a great forum"!!!
Not sure if anyone has tried this, but it “may” be possible to take one bolt out, loosen the opposing side, and then begin one bolt to the GM hardware while twisting the Ford part out of the way, therefore always keeping the back plate screwed to the front plate to prevent it falling.
So far my doors are fine, but I only have 800 miles on the truck. Lol.
Totally good idea!
It's not the weather stripping it's something in the door, loose harness bolt/nuts something...put some tape on latch and it did nothing...you cant even hear it at highway speeds...just on the dirt and back roads. Last time I took in they had tech pulled all the cactus spines out my tires with neednose from my hunting trip to NM...they have done a great job so far. Like I said I gots better things to do than mess with a truck that's under warranty.
Well this fixed one rattle!! Had to lower the back seat back on both sides and tighten up the cover on the sub woofer and also tighten the subwoofer enclosure along with what looks like an amp on the back wall. What a pain--guess the bumpy roads had taken their toll lol. ;)
Be careful NOT to over tighten the those bolts on the sub woofer. Unfortunately, they snap very easily, just a heads up..
