Door Panel Removal
No it does not stop with pushing, pulling, or punching.
I don't really think this is your issue buuut I feel I should mention it since you're chasing down all possibilities.
After getting my truck back from the body shop I had a rattle/buzz in the P side door. It would come and go with music mostly but I couldn't find it w the door apart. Turned out when the body shop reassembled everything, they routed the latch cable such that it was just barely touching something where it shouldn't have. When I had it apart but the cable still attached the tension was off it so I couldn't identify it as an issue.
Might be something to consider. 🤷‍♂️
I think something like this is what we’re hearing in that video. I’d remove the panel and verify all the cables and anchors are in place.
Today the temps were a little warmer and I didn't hear the sound. I think there is some temperature component to the issue. It never started until winter. I have to run out and get a plastic prybar before getting started. I could see it being that latch cable you all have mentioned. It sounds like a metal cable vibrating against something.
