Door Hinge Fail??
Mine ma1de noise even rattled a little. Replaced the part that the door latches to with a GM yes, a GM part. Worked like a charm. Do not remember the PN but there is a thread here on it.
How hard was it to remove the factory star bolts on the OEM striker? One video i watched about this fix, the guy in the video was concerned he may break the bolt or welded nut on the back side due to the anti-seize that Ford used. That would be my luck. Just curious about your experience with removing and installing.
Thanks
Thanks
I've loosened one strike to get a little adjustment out of it. It wasn't difficult. I'm hoping someone might try the '23 door strikes since they look a lot like the GM part.
My old F150 did that with all 4 doors. I was told that it was the inner mechanism for part of the door. Not the hinge, but another part. It would require replacing all the parts connected. (The black rod)
Thanks
Not hard at all.... No issues whatso ever. Has worked well ever since I replaced them with the GM parts. Just has to make it 4 more weeks until my new truck is built and delivered. ;)
My driver rear door crackles when I open / close it. It also crackles when pulling the exterior handle from rest to just before the point it actuates the latch. It’s not the handle making the noise, it’s inside the door.
The day I picked my truck up new, I noticed that door do the slightest “shimmy” when pulling the exterior door handle and the latch opens. It also has a rattle / knock in it going down my gravel driveway. Sounds like a bottle in the door pocket rattling against the door panel - but there’s nothing IN the door pocket.
