X2You don’t need one with those weights. If you tow in wind or fast - never hurts to have one.
Try it without and if you have conditions that give you sway then add one
Enjoy the trailer!
Enjoy the trailer!
I have a 6" drop WeighSafe True Tow weight distribution hitch. Works great and I do not need any additional drop for my TT.What drop is needed for our trucks? I was thinking 6” or 8”?
This right here.With a travel trailer it isn't just about the weight, it is also the lateral forces caused by the sail you are pulling behind your truck. The pivot point behind the axle doesn't help matters either unlike a 5er where the pivot is over the axles. I vote for getting one.
What he said!I have a 6" drop WeighSafe True Tow weight distribution hitch. Works great and I do not need any additional drop for my TT.
Same and mines gotta be up towards the topI have a 6" drop WeighSafe True Tow weight distribution hitch. Works great and I do not need any additional drop for my TT.
If you're towing a camper, then hopefully those should know that the old school WDH with chains are certainly not for big, long, tongue heavy rectangular boxes. So hopefully if you avoid those, then yes most of the correct WDH (with friction bars) will obviously have built in sway. Other than Anderson builds their setup with a chains and still achieves no sway.I personally would use a WDH with sway control of some sort.
Many of the posts in this thread imply that a WDH = sway control. This is not always the case. Sure some WDW set ups have built in sway control by MANY do not and the sway control is a separate accessory.
Great point! Thanks for clarifying.Many of the posts in this thread imply that a WDH = sway control. This is not always the case
Yes, Andersen still uses friction for sway mitigation, just at the shaft for the hitch ball.Other than Anderson builds their setup with a chains and still achieves no sway.
www.jack-back.com
This is true for ideal towing conditions. Sway control should still be used to help address abnormal conditions.A WDH can help mitigate sway but the real solution is to eliminate sway entirely with sufficient tongue weight.
Any chance you have the 3" receiver end?I have a Propride 3P hitch for sale if you're interested. Makes a pretty significant difference in comfort and safety when compared to nothing and even a standard WDH
No, unfortunately it's the 2" receiver. I used it with two reducers though with no problem the few times I towed my TT before selling it.Any chance you have the 3" receiver end?
You cruises at 70 or 80 mph while towing a Rv…am I understanding you correctly ? You have any idea of the speed rateing is on your Rv tires… to each their own but you might consider backing it down for your sake as those around you. Just saying…I use them just because you add your gear water and it adds up plus you can run the sway Control on the side that will let you cruise at 70 or 80 to me it tracks better
I have the 2 1/2" receiver on my ProPride. It's a heavy beast and I could not imagine it being even heavier with the 3". The 2" may not be a bad thing!No, unfortunately it's the 2" receiver. I used it with two reducers though with no problem the few times I towed my TT before selling it.
